Buying ebay Wheels for my '13 C63?
Received little help from the wheel forum so I've come to my immediate family in the C63 forum.
Hey guys- As I patiently await the delivery of my W204 I'm looking at what I can do for wheels. Started browsing ebay for a nice pickup and came across these, which come with off-brand tires, and Pirellis for a $300 fee: http://www.ebay.com/itm/19-Mercedes-...oAAOSwPgxVRHk9
Now, I'm a complete newbie with wheels, fitment, offset, rim diameter, rubbing concerns, the works. I know these are replica but I'm a firm believer in that if you do something to crack a replica rim you'd likely be writing off the OEM counterpart. If I do move forward with these do I need to worry about rubbing or anything else? It would be a move up from 18" to 19".
The front will fit the rear will not. Looks like it's showing a 35 offset for both front and rear. You can go at best and its pushing it depending on tire size et 40. I wouldn't go lower then a 45 for the rear setup.
'13 C63 AMG P31
There are tons of vendors on here that can help you out with fitment and style. Personally I wouldn't trust eBay wheels. A lot of sites also have wheel configurations, like HRE for example. You can also browse through the wheel thread and see what other members are using.
C63 AMG - LSD
I wouldnt trust ebay. Nothing like testing the muscle of your new pretty car just to have one of the spokes break at 120mph. Bye bye car.
Buy reputable, spend the money. You apparently have enough money to buy a C63 so you should have enough for upkeep and quality mods. Don't skimp where it counts
C63 AMG, P30
Wheels, tires, brakes: don't skimp on these.
SuperFastYo (01-20-2017)
The following 4 users liked this post by SuperFastYo:
https://mbworld.org/forums/c63-amg-w...-stickies.html
debtinstruments (01-23-2017)
Former Vendor of MBWorld
2013 Mercedes C63 AMG
I would stay away. I would stay away from any wheel that wasn't tested for strength and durability. You dont want the wheel to crack, or collapse on itself the first time you hit a pot hole.
Received 2,810 Likes
You need higher offsets. Oem are 45 front/54 rear. 35/35 is no bueno. If your budget is like $1400 I'd consider some of the cheaper aftermarket ones like the Forgestar CF5V.
There are 19" replicas on ebay that are 45/45 offsets, but way too much $$ imo. Most replica 19" sets on ebay are around $800 (there are 45/54 offsets in other styles too)
http://www.ebay.com/itm/19-WHEELS-FI...VXGCnR&vxp=mtr
Your stock wheels if staggered are 8.0 wide with a 45 mm offset in the front and 9.0 wide with a 54 mm offset in the rear.
The wheels advertised are both 35 mm offset.
This means these fronts will stick out 10 mm further in the front wheel wells and 19 mm in the rear. That is a lot.
You have no idea where and how these were made and may look pretty but be as porous as all get out and therefore unsafe.
Deal with a reputable online company who has been around for years.
As to style if your stock wheels are 19" and staggered I would trade you even up for my 19" multi spoke wheels for one reason and one reason only. Exposure of the caliper.
Look into Renn RS52 wheels they are good wheels light weight and strong and probably in your price range. The offsets are perfect and 19 wheels are flush to fenders with no rubbing.
sweet website
http://www.rennmotorsport.com
As usual everyone fear mongering about ebay wheels without probably ever having owned a set, I am surprised the infamous bbs replica wheel pic has not surfaced yet.
I had the OEM multispokes on my C63 and they cracked so easily due to the ****ty roads here in NYC. I was NOT going to pay 150 a wheel to fix those cracks when they were going to just crack again. Keep in mind these were OEM wheels that cracked.
I got these replica 507 wheels for my C63 as replacement, must have put 15k miles on them since July. The sizes were 19x8.0 and 19x9.0 et 35 with 235/235/19 and 255/35/19 p zero summer tires lowered on h&r coilovers. Fits fine but the rear has stretchy look which I do not like.
I drive my car everywhere and have hit TONS of potholes. The roads here in NYC are beyond trash and compare to roads in rural remote Iran and i bought these wheels just to see how long they will last. With that being said, after 15k miles more than half a year I have tested these wheels as much as I can. One wheel has very slightly bent but that is my fault, i hit a raised manhole cover at 80 on the BQE and slightly bent the outside lip, total cost to fix $75 NBD and best of all NO CRACKS or any other bends. That slight bend is so little I didn't even notice it and don't even feel it while driving.
I doubt your roads are worse than NYC, I think you should go for these wheels. i paid only around 800 mine came with no tires, I reused the stock tires from my oem 19s.
Hope this helps
Hope this helps
I do have a set of ebay replica 19" multispokes probably from the same factory as yours. Ironic that your OEM multispokes cracked but my reps are still holding strong (as are your 507 reps).
I really want a set of black edition 1 wheels as well to switch things up.
