E-Class (W213) 2016 - 2023
W213 Wood Trim Issue
Old 02-20-2017, 12:49 AM
Hong Young-joon's Avatar
E220D
Hello.
I am living in South Korea.
I found some gaps between wood trim and air vent in my car.
Do you have similar issue on the wood trim ?
Do you know why this happens?
Old 02-20-2017, 06:46 PM
makris0000's Avatar
2024 GLE 53 AMG Coupe
With the brown wood trim that doesn't look that big but the black wood trim looks like a pretty big gap. In mine, I haven't noticed any gaps between my vents and wood trim
Old 02-21-2017, 02:41 AM
Diesel Benz's Avatar
Have you tried to adjust the nozzles, move them towards the gap? Perhaps the hole on the wood is too big and the nozzles do not self-align properly. By manual adjustment you might be able to close the gap without opening a gap on the opposite side.
Note that I did not check how the nozzles are secured. Might be necessary to remove the panel first.
Old 02-21-2017, 05:11 AM
E220D
Thank you!
E220D
Thanks a lot
Old 02-21-2017, 11:42 AM
c4004matic's Avatar
Received 1,067 Likes on 703 Posts
17 E43; 21 GLS580
Looks like Chinese Q/A isn't quite up to German standards. That is also true of US built MB's. My C class had a few cosmetic issues too.
Old 02-21-2017, 12:20 PM
E220D
This car is German built
Yes. looks like Chinese quality assurance, but every Mercedes in South Korea is German built. That is serious.
Old 02-21-2017, 02:15 PM
ADD0514's Avatar
E300 P03
My Germany built E300 has many cosmetic issues. The loaners have the same problems.
Old 02-21-2017, 02:49 PM
c4004matic's Avatar
17 E43; 21 GLS580
Nicht sehr gut!!!!
I was hoping the ones from the "fatherland" had better attention to detail.
Old 02-21-2017, 03:59 PM
ADD0514's Avatar
E300 P03
Nicht sehr gut!!!!
Perhaps with the AMG line. It's inevitable that mistakes will be introduced along with introductions of new car and production expansions for the lower rung models.
Old 02-21-2017, 05:32 PM
teksurv's Avatar
EQ
I have similar gaps on my E300 loaner, black ash. Probably wouldn't have noticed but they are there. Adjusting vents does not solve the gap.
Diesel Benz (02-22-2017)
Old 02-21-2017, 09:06 PM
ADD0514's Avatar
E300 P03
Just a thought - Wood expands and constricts. The gap might be more visible in certain weather condition. MB might also leave a wider gap on purpose to avoid splitting the trim.
Old 02-21-2017, 09:46 PM
michaelleongcl's Avatar
E200 ML
Originally Posted by Hong Young-joon
Hello.
the singapore spec e class does not have this problem
Old 02-21-2017, 10:07 PM
Tom T's Avatar
2017 E300
Just went to check mine burl walnut wood it is pretty close to perfect. I wonder those gaps only happen on the natural wood trims. I first liked the look of the natural wood trim. But after see it in person and compare to the tradition clear coat over the wood trim, I had to go back to it.
Old 02-22-2017, 02:32 AM
Could you be more specific on that. Did you try to move the nozzle ring and got a gap on both sides? Adjusting the front part should either delete the gap or make it appear evenly all around the nozzle ring.
Old 02-22-2017, 10:14 AM
teksurv's Avatar
EQ
I tried to move the nozzle ring to see if the gaps changed at all. They did not, meaning the ring returned to the original position. There did not seem to be any "play" in terms of adjustment.
The gaps are not uniform, but as I said before, I likely would not have noticed them in an all black interior.
Diesel Benz (02-23-2017)
Old 02-23-2017, 12:21 AM
E220D
Today, I just visited Mercedes official maintenance center to ask my wood trim problem. Advisor recommends me to change wood trim. That's why he knows that to modify the position of nozzle ring is not the solution. So new wood trim will arrive after 10days from Germany.
