SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: odometer stopped working, any ideas?
Old 06-18-2007, 09:27 PM
MBFANMAN's Avatar
Hey guys, my uncle had recently bought an 500SL (1992) and the odometer isn't working anymore. Neither does the tripmeter. Any ideas? The rest of the gauges on the cluster work fine (ie: speedo, tach etc). Is this a relatively easy DIY job or best to consult professionals?
Thanks,
Jack
Old 06-22-2007, 11:28 PM
Black129's Avatar
1997 SL500
Hey no speedo no miles.... For sale... Low mile benz...
Old 06-23-2007, 08:45 PM
jjay911's Avatar
1991 300sl 5 speed manual
Try reseting the trip meter. Leave the car on and in drive and release the brake. Then hit the trip meter. see if it jars it loose. This only works if you dont have the digital type. JJ
Old 06-28-2007, 08:02 PM
agentMurdoc's Avatar
i have the same "problem" except I don't see it as a problem. Claim that you drive it an average of 5k miles a year and enjoy a reduced premium on your insurance.
I never cared to much to try and fix it. Maybe in 2 years when smog is due, cause it'll look funny if it's smogged at the same exact mileage, haha.
Old 06-29-2007, 12:23 AM
MBFANMAN's Avatar
Well, I found a place to send the gauge cluster to have it repaired for my uncle. The gears driving the odo & trip meter were all sheared off. I guess my aunt might've pressed the re-set button while moving
Old 10-20-2013, 12:03 PM
MercBimmerman's Avatar
97 BMW 740iL / 00 MBZ E320 4MATIC
(old post but useful for future reference) Not very helpful info people... You'll have to remove the cluster and take it apart. It is mechanical in design. The mechanism has jammed on the cog wheels (or wheel broke).
Spraying a small amount of lubricant may free it. Otherwise for a small amount of money you can replace the plastic wheels.
Old 07-26-2014, 08:52 AM
Mcfeelyda's Avatar
1991 SL 500
Intermittent odometer and trip failure
I have 1992 SL500. I've had gears repaired but my odometer and trip meter will work for a while, then stop working, then start working again. Any suggestions.
Old 07-26-2014, 12:01 PM
Technically it's a 500SL not "SL500"
Old 08-16-2014, 12:06 PM
petee2's Avatar
1994 sl500 85000 miles and Great car!!!
Here is some helpful info I got my gears here and they stock the gears for the sl models .
the guys were very helpful with all my questions and shipping was fast I had the gears immediatly the instructions can help a monkey do it yoursel
http://www.odometergears.com/documen...ter_Repair.pdf
Quick Reply: SL/R129: odometer stopped working, any ideas?
