SL/R129: leaking top cylinder-sl500
'95 SL500
I need help on the instructions for the removal of the cylinders (leaking) next to the windshiled for the convertible top. Anyone have any thoughts? I was told someone here might have a video on line. Anyone know where I can find it? Thanks in advance!
'87 560SL Sold, '99 SL500 For Keeps
http://www.peachparts.com/Wikka/R129TopRelease
Many of us have the two cylinders rebuilt by Dennis Ficken in KS. Fast turnaround(couple days), inexpensive at $50@, and warranteed for 3yrs. If you decide to use him too, his contact info is
Mercedes Hydraulic Cylinder Rebuilder
Dennis Ficken
16285 S. Chester
Olathe, Ks 66062
(913) 390-0506
mercedescylinders@sbcglobal.net
Good luck, have fun-
Bob
1998 SL500, Pano, Black/Black
There is a fellow in Kansas who rebuilds the cylinders for $50 each. Here is his contact information:
Dennis Ficken
16285 S. Chester
Olathe, KS 66062
(913) 544-4521 Cell
Drop him an email and he will send you detailed instructions about how to R & R all of the cylinders. I have used him - he is great; I sent mine out on Monday from GA, had them back Saturday. He warrants his work for 3 years as long as you haven't used a stop leak product in your system.
Follow his instructions to the letter, especially the part about having all of the latches in the same position - either latched on unlatched; it is a good DIY project. I did the rear latchs, tonneau lifts and front latch cylinders - took about an hour to remove and two hour to reassemble. works great with no puddles behind the rear wheels.
Good luck..
Dennis Ficken
16285 S. Chester
Olathe, KS 66062
(913) 544-4521 Cell
Good luck..
Cylinder rebuilds
I thought I'd use Dennis Ficken as well. But then I dug some more in benzworld.org and found that Top Hydraulics, Inc. does the same thing. What sold me on them was that they are posting R&R instructions on their website, they are using better seal material than Mercedes, I could pay with a credit card, and they encouraged me to send the cylinders in with the locks attached. It looks like it saved a lot of work not to have to separate cylinders from the locks, and they did not charge extra.
Actually, I PMed several of the people on benzworld who had used Dennis Ficken several years back and asked if the cylinders had lasted. One wrote back that it had to be fixed again after two years. Maybe he is using the same material as Mercedes?
I mailed my package to them on Monday, and had it back on Friday. Couldn't be happier with the service.
Here is the info for Top Hydraulics:
www.tophydraulicsinc.com
541 902 3214
They have announced on benzworld that they are going to replace people's cylinders on the spot with a traveling mechanic - hooray!
541 902 3214
Dennis Ficken
16285 S. Chester
Olathe, KS 66062
(913) 544-4521 Cell
Good luck..
Dennis Ficken
16285 S. Chester
Olathe, KS 66062
(913) 544-4521 Cell
Good luck..
Glad Top Hydraulics worked out for you; sounds like both are good - I had similar service from Dennis; cylinders out on Monday (Atlanta to Kansas), I had them back and installed on Saturday. Dennis will send PDF instructions to you via email, and does accept locks with cylinders still in them (although I can't imagine anyone who is capable of pulling the latch to be incapable of using a 5mm or 6mm to remove the cylinder from the latch). Dennis does say he uses different seals from the MB seals, and he does warranty his rebuilt cylinders for 3 years as long as you don't use stop leak, so your "PM failure" should have gotten his fixed for free since it was at the 2 year mark. Credit card capability is a nice feature with Top Hydraulics, but I just put a check in the box I sent to Dennis.
It is good to have two sources.
