You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
The oil level sensor on my '02 SL600 is leaking - I suspect one of the O-rings that seal the sensor in sump is starting to perish.
Question: Does anyone know if there's a trick to removing the sensor? I dropped the oil pan, only to find that there's a bracket/baffle that obstructs removing the sensor. The bracket is held on by three bolts, one of which (nearest the sensor) can be removed via an access hole, the second (in the center, near the oil pump pickup) is easily removed, but the third on the opposite side of the sump looks to be impossible to get to (of course MB didn't make an access hole on that side, but they could have!). To me, it looks like you have to remove the sump casting, not just the oil pan to get to the third screw - and it's not at all obvious that comes off w/ the engine in the car - the bolts on the front and side are easy to get to, but not sure about the one that are under the body/suspension cross member.
Looks like I might (?) be able to remove the two accessible bolts and bend the bracket out of the way - but that just seems wrong.
I really don't want to have to pull the V-12 to replace a $3 O-ring!
To remove this ad, register today or login if you already are registered!
