Go Back   MBWorld.org Forums > Mercedes-Benz SLR & SL Roadsters > SL-Class (R129)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 08-11-2012, 02:05 AM   #1
Drives: SL 500 1995
'95 SL500 Test drive
Hi Guys,
Took the SL500 for a drive today and here are some things I found
Gearbox
Smooth gear changes, however overdrive took too long to engage. Low gears fine, no feathering but 3rd to overdrive somewhat hesitant. Is this usual? It was cold though and it really only got up to operating temp by the end of the drive. Is this usual?
Throttle
Throttle pedal was quite firm to press down. The yard did have the cable replaced. It worked perfectly but is it usually that firm?
Speedo and MPG/L per 100 guage were not working. They were last time I looked at it? Any ideas on what the issue could be?
I didn't have time to check soft top operation however I did see it working last time.
Any ideas/recomendations on the above would be much appreciated.
On the bright side, it looks like my potential offer of 4k below their sale price looks to be accepted by the owner.
Mark
To remove this ad, register today or login if you already are registered!
OzyMark is offline   Reply With Quote
Old 08-11-2012, 09:59 AM   #2
Drives: 1994 SL 600, 89 XJS Conv., 13 Hybrid Av 11Chevy crewcab
Did all part of the instrument cluster work? Once is not enough on the top! Latching down the hard top is worthy of your examination. Did you run the fan speeds on the AC? As you may have read the 93-95 R129's have harness issues.
Both forums have great information including a buyers guide. The time you spend on research will be a great investment, if nothing more than cocktail party chatter! The money to buy the car is pocket change next to the repair and restoration expenditures!
SRHsl600 is offline   Reply With Quote
Old 08-11-2012, 10:29 AM   #3
Drives: SL 500 1995
Everything worked except for the speedo and fuel economy gauge. Tachometer, fuel gauge, engine temp, warning lights all worked fine. Ran out of time to check the rest but will certainly do a thorough inspection before buying. Where can I find the thread on common faults for this model eg wiring harness etc. Had a look at stickies but could not find anything. AC worked well, ice cold, fan speeds worked well also.
Mark
Tags
1995, 95, cold, drive, misses, r129, road, sl500, test
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
