SL/R129: Dome Light Assembly Removal
2009 SL 550 Silver Arrow Launch Edition
Can some one guide me (pictures, step-by-steps) through removing my Dome Light Assembly? I want to start with replacing the switch that controls the dome lights with the door. If this does not fix my problem, I want to replace the whole assembly.
Your help is appreciated.https://mbworld.org/forums/images/smilies/bowdown.gif
Thanks!
Thanks!
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
I have removed the interior rear view mirror and changed the interior light in my 600. The access for the windshield lights are there. The mirror is a spring loaded attachment, so that the mirror is a "break away". Once you have the mirror un-sprung there are wire connectors. I remember 2 or 3 threaded fasteners, then the plastic housing can be removed. The door switch is in the door frame post.
I used a video to to learn the first access, but have not seen recently. Good luck
Thanks so much. Does the mirror snap back in when I am finished?
Yes, as long as the spring connector was not broken. I normally launch into the "old plastic" reminder, so often I order new plastic to replace the removed, but MB does not give the parts away, so expect expensive!
