SL/R129: Hydraulic Top Reset
Hydraulic Top Reset
Having a problem with the Top ...
I can get the hard top to release and lock down.
I can also get the soft top to come up and close and go back down..however, after I put it back down,,It doesn't want to comeback up after the first cycle. The only way I can get it to come back up is to disconnect the battery for about 5 or 6 mins, then reconnect battery, get in the car, start it and push the RED button forward and the top comes right up and locks into place. Then when I want to put the soft top back down, it may work just fine or it will get about halfway up and stop, and not go any farther until I do the disconnect the battery trick.
The bottom line is it normally will recycle one time then you have to reset everything by disconnecting the battery....I'm trying to figure this out but haven't been able to yet..Anyone have a Ideas..where the problem is..I have no Leaks anywhere in the system and the pump is full and seems to be working fine..Any help wpuld be greatly appreciated..Thanks in advance and Happy Motoring !!!
