SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: radio code
Old 08-27-2014, 07:58 PM
98sl500's Avatar
2008 e350, 1998 sl500
radio code
I have a '98 sl500 that I had to disconnect the battery over night to clear one of the controllers. When I reconnected the battery I had to input the radio code. After three unsuccessful attempts, it seems the radio has locked and won't accept any more code input attempts. I know the code is good because I've successfully used it before.
Does anyone know if there is a limited number of tries inputting the code and, if there is, how can the radio be unlocked?
Thanks for any help
Bob
Old 08-28-2014, 02:29 PM
Je Suis Moi's Avatar
1992 400E, 1997 SL500, 2009 R350, 1998 SL500 (for sale)
This should help. It's from the radio manual for my 1997:
ANTI-THEFT SYSTEM
The Mercedes-Benz AM and FM stereo radio with
cassette player and CD compatibility is fitted with a
built-in system designed to help render it
inoperative in case of theft. If the radio or battery is
disconnected, the radio will automatically be
disabled. To indicate this state, the word
CODE will
appear on the radio's display. To render the radio
operable again, the correct five digit code must be
entered into the radio via its numbered station-recall
buttons. A code is reassigned to each radio and
supplied to the owner on a wallet-sized card.
RECODING SEQUENCE
To recede a radio, follow this procedure:
1. Turn ignition key to lock position one. 2. Turn on
the radio. The word CODE appears on the display
with the letter "C" flashing. 3. Enter the first digit of
the radio's anti-theft code as it appears on the code
card. The word CODE will disappear and the first
number that you have entered will be displayed,
followed by four dashes. e. g. 1 . 4. Enter
the rest of the five digit anti-theft code. Each
number will be displayed when it is keyed in. 5.
When all five anti-theft code numbers have been
correctly entered, the first number in the code
flashes, alerting you to confirm the code. Press the
Scan (SC) Seek or Tune button to confirm the code.
Radio operation will now resume.
INCORRECT CODE
If an incorrect anti-theft code digit is entered,
continue to enter numbers until the five-digit code is
correctly entered and displayed. If an incorrect code
is confirmed, the word
CODE will appear again. The
system allows two more receding attempts. After the
third attempt, the word
WAIT is displayed. A period
of 10 minutes must pass and the word
CODE must
again be displayed before receding can be
successful. The radio must be left on during this
period. This measure is meant to prevent receding
of the radio by randomly entering numbers.
Old 08-28-2014, 04:10 PM
98sl500's Avatar
Thank you. Finally got the radio working again with your information.
Quick Reply: SL/R129: radio code
