SL/R129: Where to next ?
1997 sl500 83 Elcamino 05 Caddie
Where to next ?
Good afternoon all, I could use a little help.
97 Sl500 It's been sitting a while. Got a ck.eng. light & the code said miss fire on 7 &8. So I put new plugs in 7 & 8 (decided to see if that was the problem before putting in all 8. ) the light went out . Test drive time. Runs smooth in town @ 100-mph then back to the low end miss & ck.eng. light came back on. It is not overheating ( just put in new rad & fuel pump, yes I drained the tank) All the fluids are fresh.
My question is what would be the next logical step in diagnostics ?
1998 SL500
Same codes (P0307 and P0308)? Does your scan tool let you pull the freeze frame data?
You could try swapping the COPS an see if the misfire follows them...
BTW, "100 mph"--gotta' love Florida don't you?
