SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 1992 300 SL - no spark from coil - desperate
Old 12-02-2014, 09:24 PM
grg334561's Avatar
1992 300SL ; 1996 S320 L
Hi everyone!
as stated above am already desperate as I've done all of the following and still cant' get the coil to generate a spark:
1. Checked / replaced OVP for good measure
2. Checked / replaced / checked for voltage at the Crankshaft position sensor - registered correct resistance and AC current generated during an engine crank
3. replaced Coil , and high tension wires , distributor cap and rotor
4. replaced the EZL (have tested with other M104.981 engines) and works (in fact I have 2 EZL's now because I initially couldn't find another M104 engine to test the first EZL I bought)
5. there is voltage to the coil terminal but during cranking - i don't get a ground into the coil that is supposed to enable a spark from the secondary into the distributor - also did the test of pulling out the coil to distributor wire and connect a known working sparkplug and ground it to the engine lift point and still no spark. - also tested coil with test light - still no ground into the coil
6. checked engine Temp sensor for resistance - working ok
7. has no engine immobiliser
Is there anything I missed?
the car has been working fine and running great as I use it every day. I got home last August 19th 2014 in the evening and the next day it just cranks but from then on, no spark
would appreciate any help - i've been to the benzworld forum and the guys there have also been sending things to test but I'm hoping for more opinions from here as well
thanks
Glenn
Old 12-04-2022, 08:36 PM
islandman's Avatar
1992 R129 500 SL
No spark from coil
Originally Posted by grg334561
Hi everyone!
thanks
Glenn
Good night guys I am from the islands I have a 1992 500 SL R129 and I have that same exact problem can someone please help me with this problem
Quick Reply: SL/R129: 1992 300 SL - no spark from coil - desperate
