SL/R129: 1991 R129 Clunking when shifting
Hello.
I have a 91 R129 w about 50K miles. When cold I get a fairly severe clunk when shifting from 1st to 2nd and again 2nd to 3rd. After driving 25 or more miles the noise becomes intermittent...in some case, goes away all together. The noise seems to be at the rear or the car. The universal joints seem to be very good. I cannot see any excess wear in the rear end or suspension.
Any ideas?
Any ideas?
'87 560SL Sold, '99 SL500 For Keeps
Hello.
Any ideas?
Any ideas?
Click here: Your Parts Search Returned 2 Part(s)
The link apparently didn't copy in. The parts can be viewed at autohausaz.com
Once installed, it will still have to be adjusted to your liking.
And finally, the clunk does sound like it's coming from the rear of the car, but in the vast majority of cases, the clunk is simply the result of the harmonics of the car, i.e., fault starts out in transmission and travels via drive shaft to rear, then clunks.
Please report back what you find out from your tech/trans shop.
Bob
Thanks Bob,
Very helpful advice. I failed to mention that when cold, I get a very long shift from 1st to second...usually it is the first shift of the day. If I let the car warm up for more than 2 minutes it is not nearly as bad. I live in Minnesota, but the car is garage kept in a heated garage @ 50 Degrees F. This is when the clunk is most pronounced.
I will check the entire system for vacuum challenges. Given the car's age, I am ordering both the modulator and the plastic cap.
I will replace early next week (I have a lift so this is not so bad) and let the forum members know the results...
Les
Les
Thanks Bob,
Les
Les
Re: Cold shifts- Our cars start out in 2nd, unless manually put into 1st, or you put the accelerator to the floor as in drag racing. The shifting is normal for MB. When cold, the shift timing is elongated to increase RPMs to warm the engine and make heat available quickly. If you always warm the engine for 2 minutes you won't hurt anything, but, waiting until the idle controller brings the idle down to normal RPMs (roughly 30 seconds) is plenty of warm up...get goin'
Re: Parts you order-A replacement modulator comes with a cap so you really don't need to order one unless you want a spare around. This is the specific component within the modulator that fails most often.
Good Luck and have fun-
Bob
Hello Bob,
New part is installed. Any suggestions regarding the adjustment procedure? Right now, I have it centered.
Can you explain the impact of rotating the adjustment knob?
Thanks, Les
One other comment. Star indicates that there are in fact two modulators. I verified with MB parts that the recommended part at Autohaus replaces the version originally installed before 7/92.
Thanks, Les
Hello Bob,
These are essentially the same question. Memory ain't what it used to be so I'll have to look up the answer later today and get back to you. That said, even leaving the knob centered should have improved the shifting to some degree. If you've had no improvement, before adjusting anything it would be prudent to verify consistent vacuum at both ends of the line as mentioned earlier.
Thanks, Les
Thanks, Les
To adjust vacuum at the modulator, turning the adjustment counter clockwise increases vaccum to the trans and will make shifting smoother. Conversely, clockwise turn makes shifting 'firmer'. I pulled up a video on youtube that does a better job explaining the adjusting steps than I could write. When you open the link, you can skip over the ad for trans rebuild kits to get to the adjustment steps. BTW, this video was NOT made using your specific transmission, but the adjustment steps are the same. Remember to turn only one 'click' at a time, then test drive. If OK, then stop. If not OK, turn one more click and repeat test drive. Good Luck-
http://www.youtube.com/watch?v=mL6zZiYIn2E
Bob
Bob
Bob,
A BIG THANK YOU!!!! The vacuum issue was difficult to find...I had a melted hard plastic line above the transmission. Could not see it...but eventually found it. Shifts as smooth as glass.
I will leave the adjustment as it is. Thank you again!
