SL/R129: misfire
1998 SL500
Bad spark plugs;
Bad plug wires;
Bad distributor rotor;
Bad distributor cap;
Bad ignition coil wire;
Bad ignition coil;
Bad fuel filter;
Clogged air filter;
Bad fuel;
Low system voltage (possible battery/generator/regulator problems);
Low compression when hot (worn piston rings/leaky valves/bad head gasket);
Worn timing chain;
Worn timing chain guides;
Worn crank/cam pulleys;
and a myriad of other problems...
- How many miles on the car?
- When were the spark plugs last changed?
- When were the plug and coil wires last changed?
- When were the distributor cap and rotor last changed?
- Has the ignition coil been tested?
