SL/R129: Why is hydraulic fluid leaking from....
Found hydraulic fluid leaking from this "plug" today while changing the shocks.
Before I start tearing things apart, has anyone seen this particular issue before? Is there a connection in a line that runs in the interior rocker panels that needs to be tightened or a new o-ring installed?
If I push up on this thing, it gives way, so it's not solid. Hope that helps.
Thanks.
Thanks.
'96 SL600, '05 S55 AMG, '06 C230
Look for a leaking actuating cylinder in the soft top storage boot area. When they start leaking, the fluid drips through a water drain hole in front corner of the storage area, each side.
Cheers,
Jeff
Cheers,
Jeff
Here are a couple of pics from under the tonneau cover with the top up. Everything looks dry. I'm still leaking fluid from the spot I show above when I actuate the top. Notice in the second pic the largest cylinder with the weep hole next to it(main lift cylinder I believe). Maybe this is where the leak is? Can't get my hand down there to check. Can anyone point me to a write up on how to get to the bottom of this cylinder(and eventually remove)
to check? Do I need to remove the inner wheel cover?
Sorry the pics are so big. Just found a write up on Top Hydraulics on how to remove. Pretty involved. I think I'll give them a call in the morning just to get their take on this before I tear things apart. Their write up says that when these main cylinders leak, it's at the top, so I should have seen fluid when I inspected, Maybe just a loose line at the bottom?
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
Many of us have been pleased with the efforts and products of Tophydraulics.
Good luck. If one is leaking the rest will follow!
