SL/R129: Coolant Temperature Sensor
Is there a fix or replacement CTS that would lower the running temperature of the coolant by regulating the fans more frequently?
97R129-01W163-94E320-93500E
You put a 1.1k resistor across the 2 poles of the temp sensor. In other words, you connect (short) the sensor's 2 poles using a 1.1 k resistor.
1992 400E, 1997 SL500, 2009 R350, 1998 SL500 (for sale)
Thanks EDCARLS
Did as EDCARLS suggested and the engine runs much cooler. Thanks for the tip! Total cost 25 cents for resistor and ten minutes to solder the two wires.
