SL/R129: OBD 1 Codes
1991 Mercedes 300 SL
OBD 1 Codes
I have a 1991 300 SL on which the Check Engine Light just started coming on (not on cold start fwiw but always after a few minutes or running or when warm starting).
I Jury rigged an OBD 1 flash counter for the 16 pole diagnostic connector and using Pin 1 as the momentary connection counted these results:
Pin 3 & Pin 8 = 17 flashes then if done again 22 flashes
Pin 3 & Pin 13 = 17 flashes then if done again 22 flashes
I've downloaded the Baum tools CS1000 Instructions which I think reports
8-17 = Crankshaft position sensor faulty
8-22 = O2 sensor voltage is too large.
but nothing for 13-17 nor 13-22.
Suggestions or directions to more clear diagnostics for the R129 would be much appreciated!
