SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 94 SL 600 ASR light - Safe Mode
Old 09-28-2016, 10:55 AM
npmart's Avatar
SL 600
I have seen and read similar situations on here but wanted to add some details to my situation and see if any one has any thoughts.
1. I took the cluster out for repair and drove the car - Started running in safemode
2. Put the cluster back in and reset the computer with the key/gas peddle to the floor and 2 minute wait. Fixed the cluster but didn't take it out of safemode
3. Took her to an Indy and they put it on the computer. Couldn't get the car to come up on the computer however, when I left she was no longer in safe mode. Drove for about 30+ miles, pulled into the driveway and she went back into safemode.
4. I have also unhooked the battery - Nothing changed.
5. ASR light is on when in safe mode
I have it at a new Indy - Just wanted to see if anyone had any thoughts other than the wiring with the fact that it came out of safemode when it was first put on the computer.
Old 09-28-2016, 11:42 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Have you used a pulse counter in the diagnostic socket to record the number of "blinks------the number of blinks tells you the fault.
However the good news is that the ASR lamp is on--check\test the wheel speed sensors and reluctor ring!!
npmart (09-28-2016)
Old 09-30-2016, 02:54 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to R129 forum...
Old 10-04-2016, 09:46 AM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
the wiring system could still be an issue.
The instrument cluster removal may have cracked the wiring insulation. (Many other wire manipulation of ant kind has started problems for my 600! ) Harness replacement does not renew all the wires!!!
The 94 has the old diagnostic blink system and the early digital system. clearing all the codes is important, but I would look at the wiring!
Quick Reply: SL/R129: 94 SL 600 ASR light - Safe Mode
