SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 1991 300 SL slow off the line
Old 01-16-2017, 11:38 AM
crangip's Avatar
1991 Mercedes Benz 300 SL
Hello,
My 1991 300 SL is pretty slow off the line. Although it isn't a consistent thing it happens more often than not. I have had the fuel filters replaced, the fuel pumps replaced, the fuel injectors and all the little rubber hoses that go with the injectors replaced as well. I haven't yet replaced the fuel distributor. The car is stil slow off the line. It is sluggish and my fuel economy, as a result is bad. Before I spend another several hundred dollars trying to rectify this problem can anyone suggest a remedy for this issue? I have looked on previous posts to see if there is anything related to my question and didn't find the information I need.
Thank you,
Phil
Old 01-16-2017, 06:21 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Yep, donate the car to a fish farm
pator60 (04-11-2017)
Old 01-17-2017, 11:13 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by crangip
...can anyone suggest a remedy for this issue?
I would familiarize myself with the diagnostic manual for this engine. I would check diagnostic codes on socket 3 for the fuel injection and proceed from there.
Old 01-25-2017, 01:19 PM
Auzivision's Avatar
90 300SL, 04 VW Phaeton, 87 Porsche 928, 83 Coupe Deville, 92 GMC, 74 Alfa SPider,
I wouldn't only focus on fuel. It could be ignition related. My 90 300 can be real doggy some days and real zippy others.
I have found that if I "row" the gears myself, it's much more responsive. I believe these normally start and second gear and only downshift to 1st under heavy acceleration and /or activation of the kick down switch.
It's kind of fun, start in low to lock in first gears... run up past 3K RPMs, push forward momentarily and pull back to lock in 2nd. Keep accelerating till you feel the need to 3rd, slide forward a notch. Keep accelerating, move forward one notch for forth, then finally "click" to the right for 5th for steady state speed.
Old 01-25-2017, 03:37 PM
bobterry99's Avatar
That's how I drove my 300. For me it made it more entertaining than a 500.
Old 01-28-2017, 10:44 PM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
I hope you replaced parts that weren't meeting specs!
You do have a heavy car with a wonderful but not powerful engine. I never considered the 300 in the 90's a power producer, but in the 300B from the 50's that was and still is a head turner, not a torque monster!
Old 01-29-2017, 01:36 AM
Russell Ormerod's Avatar
not a merc
Check fuel pressure! Check current to actuator on fuel distributor! Diagnose it properly you won't need to replace parts for nothing
Quick Reply: SL/R129: 1991 300 SL slow off the line
