SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: MAF-Mass Air Flow Sensor-supply almost gone
Old 02-13-2017, 05:37 PM
Lee Wireless's Avatar
1995 SL500 - 2017 AMG GLC 43
The MAF (Mass Air Flow) failed in my car. Symptom: car stumbles when it accelerates and sometimes stalls when coming to a stop. Eventually threw a CEL (Check Engine Light). Blinking code reader indicated bad MAF stating under voltage or open/shorted. Tried cleaning MAF with CRC brand MAF cleaner. Cleared codes and CEL with code reader. The cleaner seemed to work at first because the engine actually started a lot quicker. I thought I solved the problem. Went out for lunch and hit the expressway. As noted in the attached document, the car ran fine until I barely applied peddle. Then the engine would stumble. Let up on gas and all seemed well. Got back home and read codes again. Same fault. Then the fun started. Try to find a MAF online or at the dealer. I called my dealer and was told none available anywhere. Went online and found a great deal at Parts.com, ordered buy reply came back that part no longer available. To make a long story short, I found one MB part number rebuilt unit at Pelican parts and boy did I pay for it. Was told they bought all remaining stock and they only had 2 left so they have the market cornered which is fine since I need the part. I'm not going to park my car and part it out because they were smart buying up the few remaining rebuilt units out there. My 22 year old SL500 looks great, will drive great again when the MAF is installed and I will now keep an eye out for items that need replacement. I just ordered a set of MB spark and coil wires from the dealer and was to there are only now 2 more left in the MB parts system. After market sets are available but there is a big variation in plug wire length vs. the MB set. I also ordered a full set of MB breather hoses as mine are as hard as a rock. Good luck....
Old 02-13-2017, 11:36 PM
miike's Avatar
2002 G500, 1961 190b, 2001 SL500 Sport
Looks like plenty available online
Old 02-14-2017, 07:34 PM
Try to buy one and have it delivered.
Old 02-16-2017, 07:24 PM
benzcollector's Avatar
ML55, ML430, 600SL, 190E 16V
I have a brand new Bosch reman MAF on the shelf for a M119. PM me if you need one.
Old 03-03-2017, 04:05 PM
Thanks. Found one at Pelican Parts before I saw your post. Yours is gold...
Old 06-04-2017, 07:03 AM
kunzet's Avatar
'02 SL500
AutohausAZ is another online source. Bought a brand new Bosch unit for my 2002 just 3 weeks ago.
