SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Door panel removal on a 97 SL500
Old 02-22-2017, 03:26 PM
Brian McL's Avatar
'90 500SL '07 C280 '98 E320, '19 C43
This is a 97/98 SL500 and I need to remove the DS door panel. I have removed the panels on lottsa 91/92/93's and it's pretty easy, but this 97 has a completely different door panel.
Does anyone know if there are any instruction on removing this model panel?
I can't find anything. All the instruction and videos are for the earlier door.
I've attached a picture.
Old 02-23-2017, 09:19 AM
Plutoe's Avatar
Received 1,052 Likes on 973 Posts
1999 E300TD
post your VIN
Old 02-23-2017, 10:41 AM
Brian McL's Avatar
WDBFA67FXVF150656
Old 02-23-2017, 01:28 PM
Plutoe's Avatar
1999 E300TD
Originally Posted by Brian McL
Attachment renoved
Old 02-23-2017, 01:50 PM
Brian McL's Avatar
That is great. Thanks for the .pdf
Old 02-23-2017, 02:57 PM
Brian McL's Avatar
Plutoe do you have a wiring diagram for the DS window motor. I need to test it and thought it would be just 2 wires....but there are several. I need to know which 2 to supply 12V to to test the motor. Thanks
UPDATE.....checked the motor...it's fine.
Code some undefined codes with the code reader. Are you able to find a definition?
Described Code 134 ----convenience micro switch L S86 R S87sl trunk S88sl
" " 101 front power window motor hall effect sensor not synchronized
" " 99 Left front power window motor hall effect sensor
Code shown with no description: 123 / 103
Any idea what they are.
Looks to me to be a problem with the roof control module.
Old 02-24-2017, 07:53 AM
Brian McL's Avatar
Micro switch location / replacement
Originally Posted by Plutoe
See attached
Plutoe do you have any information on the location of the driver side window micro switch and instructions on replacing it?
Thanks again
