Sign in using an external account
| SL-Class (R230) 2003 -- 2012: Discussion on the SL500, SL550, SL600 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2006 SL600, 2001 S500, 1996 SL320
Nail in Tire
__________________
2006 SL600 - Black with Stone Exclusive Leather
#2 |
Drives: Bentley Arnage Red Label
I had one in my Bentley last week and they pulled it out and plugged it with the wheel on my car in 5 min. Shouldn't be a need to take the tire or wheel off.
__________________
Jeff 02 G500 05 SL 65 Silver Arrow 00 Bentley Arnage Red Label 06 Infiniti QX56 06 MV Agusta Brutale "R" 07 HD Night Rod Special 07 Bentley GTC |
#3 |
Drives: SL500 and SLK320
Need to take pictures of your rim and show the manager your rims before they even touch it. If the manger asks why, just tell him I had bad experiences in the past from other companies and I just want to protect my self. When you do this, he will make sure he has the best most careful person working on your car. The comapanies here will pay for your rims to get fix if they damage them.
Maybe the dealer has the torque information. |
#4 |
I hope so.
What makes the difference, in the past it always seems like they take the tire off the rim when they have done something like this for me in the past on other cars.
__________________
#5 | |
Drives: 2012 S Class designo
Quote:
An internal patch is the minimun you should do and would be a good acceptable repair. My dealer won't use plugs. They claim they are not safe enough. |
#6 | |
Quote:
I am sure you can get a new tire if you want to spend the money. I don't have any issue with the plug. The way it works I don't think you could get something to happen to the plug if you tried. If it was an issue, reputable tire places wouldn't use them and they do all the time.
__________________
#7 |
Drives: 08 CL600 Black
I've had two nails on two different tires in a span of 8 months. The first nail was at 1100 miles. The 2nd was at 6600 miles. Both were replaced. My dealer refused to patch or plug for safety reasons.
__________________
'08 CL600 '10 HS250h |
#8 | |
Drives: Several MB's
Quote:
I have had this happen to me as well. Find a good tire shop and they will have to take the tire off to do it correctly. They will also re-torque the wheel to the exact spec's and not use an impact wrench. However based on your latest test drive at 110mph, I would get a new tire. If you drive at normal speeds, the repaired tire will do just fine. Since you are going to get a new car, slow down and let it go with the repaire tire.
__________________
Lou K |
#9 | |
Quote:
Jeff,That is not the way to proper way to repair a tire. They have to finish and seal the inside as well. That was a quick fix that, if I were you, would have repaired properly.
__________________
Lou K Last edited by lkirchner; 05-08-2005 at 08:58 PM. Reason: correction |
#10 |
Drives: '04 S430 4 Matic and '05 997
Using a plug is not the proper way to fix this. it needs to be repaired from the inside so that the tire pressure helps to maintain the seal.
I had winter tires installed at my local Firestone dealer (on my previous MB) figuring what could go wrong they do this all day. Well they stripped the threads (which are on the rotors on MB and BMWs) and could not fix it. Had to take it to the MB dealer and they fixed it under warrantee. Eventually they stripped several other lug nuts, damaged my rotors (which had to be replaced) and would accept no responsibility for overtorquing the lug nuts. (Even though I gave them the torque specs. They said this was MBs problem because it is a poor design). Don't trust ignorant ***holes like this to even add air to your tires much less fix them. |
#11 |
Drives: 1951 Caterpiller D6
A few rules when fixing flats in high performance tires....
1. Absolutely never ever use a plug to fix a flat. You are risking damage to your car if it lets go at speed and maybe even risking your life here. 2. After the tire is patched, it is very important to remember that the tire will now be one speed rating LOWER. Only selected Michilen dealers can repair and maintain speed raitings...SOMETIMES. 3. If you have to put a second patch on a tire, get rid of it. This advice comes from someone who was in the tire and performance biz for 30+ years. |
#12 | |
Quote:
#13 | |
Drives: g
I agree why not take it to Goodyear or somewhere... most of the times if their not busy their glad to do it for free.
__________________
03' Lamborghini Murcielago - ![]() 04' SL500 - Brabus Monoblock Style VI 05' Escalade ESV - 22' Giovanna Anzios 06' F430 Spider - No thank you Quote:
#14 | |
Quote:
I recently had my brakes treated with anti squeal paste (which did nothing BTW) and warned the tech to use great care not to scratch the rims, well he took off small amounts of paint around the lug nut holes on 3 of the 4 rims; I touched them all up wit rim paint and clear coat but upon close inspection it still shows...so much for a $40.00 tip.Plugs can work and you never have to worry about rim collateral damage but it's really not the best way to repair the tire vs. using an internal patch.
__________________
RJC Your character is determined by what you do when no one is looking... 2013 SL550 w/cooled seats tbd Previous MB's 2006 E55 AMG, 2004 CLK500, 2003 CLK500, 2001 CLK430, 2000 CLK430, 1999 CLK430, 1992 300CE. Previous Other Marques Jaguar, Porsche, BMW, Lexus, Ferrari, Corvette Last edited by RJC; 05-09-2005 at 07:51 PM. |
#15 |
Two tire shops and no luck today!
I went to tire shops today and no luck.
The first was big ten tires, the rep came out looked at it and said no problem we can fix it, but he wanted the manager to look at it, the manager said again no problem we can fix it, but that I would need to sign a waiver about the rim. I asked him why, and he said he didn't want to have to buy me a new rim. I said so you're telling me you are going to damage it then, he said well our equipment is ten years old. I said thanks, but I will try someplace else. The place he recommended I go was up the street, I stopped there and they said I wouldn't have to worry about the rim they would just plug it. I told them I heard that was not safe, he said it would be ok. I again passed and will try again tomorrow or Wednesday. Can't believe getting someone to fix a tire without damaging something is that hard to accomplish. We complain about Mercedes Quality, it is spreading.
__________________
#16 | |
Quote:
Nope, if I got a nail in another tire tomorrow I would plug that one as well. The way a tire is constructed their isn't an issue with it. You guys can spend all the money you want, it doesn't bother me. A plug fills the entire hole and bonds with the rubber. How many people have had a plugged tire rip apart because of the plug?
__________________
#17 | |
Quote:
To answer your last question, thousands of tires come apart everyday due to improper repairs. |
#18 |
Drives: 2010 Range Rover S/C 2010 Land Rover LR4 HSE Lux Plus 2007 BMW R1200GS
I got a tire/wheel warranty that will replace any tire with a nail, or a bent rim. Amazingly, the warranty was only $240.00! (6 year/75000 miles) I have a slow leak in my right rear right now, so I am going to find out how good they are.
#19 |
Drives: C230 coupe 2003
Just to reiterate regarding proper puncture repair, please visit:
http://www.tirerack.com/tires/tirete....jsp?techid=27 Here is an excerpt: "Any repair done without removing the tire from the wheel is improper. Without inspecting the inside of the tire for hidden damage comes the risk of returning a weakened tire to service. Punctures in the tread area that looked repairable have revealed upon further investigation that the object that punctured the tire had been long enough to cut the tire's sidewall from the inside. Without dismounting the tire, the hidden damage would have been missed. Simply "plugging" a tire from the outside without removing the tire from the wheel is improper. (If a tire is punctured while off-roading far away from civilization and a spare tire isn't available, a plug may serve as a temporary low speed solution which must be replaced with a proper repair as soon as possible upon returning to the road.)..... How do you know which procedures a tire dealer uses? Ask them! But be aware that if they say that they can repair a tire in 10 minutes for under $10 dollars without removing it from the wheel, they aren't following the Rubber Manufacturer's Association procedures. A correctly done flat repair that follows the multi-step repair procedures will take approximately 30 minutes and probably cost around $20." Last edited by REX0000; 05-13-2005 at 05:26 AM. |
#20 |
Drives: SL55 AMG
It's one of the hazards of owning 18" wheels that the rims can be damaged replacing the tyre. I'm happy to drive 150 miles round trip to get tyres changed because I know the company (for those in the UK: Micheldever Tyres) use state of the art tyre changing equipment and will not damage my rims. As for repairing a tyre, I always replace the tyre, no question.
__________________
blueSL 2012 Range Rover Evoque Coupe Dynamic - Firenze Red/Ebony 2010 Porsche 997.2 turbo PDK - Aqua Blue/Dark Grey 2005 Subaru Impreza WRX Wagon - Silver/Black 2003 Mercedes-Benz SL55 AMG - Brilliant Silver/Berry Red 1995 Ferrari F355 Berlinetta - Rosso Corsa/Crema |
| Tags |
| big, car, leak, lug, mercedes, nail, nut, repair, replace, sl500, sl550, slow, specifications, ten, tire, torque |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| The Tire Rack FAQ Thread | Luke@tirerack | Wheels, Tires, Suspension & Brakes Forum-Sponsored By Tire Rack | 5 | 12-13-2006 03:29 PM |
| Plans for Winter in your C230 | BabyBenz6spd | C-Class (W203) | 86 | 11-16-2005 11:54 PM |
| All cars to have Tire Pressure Monitoring System by 2008... | GDawgC220 | Off Topic | 1 | 04-08-2005 10:08 AM |
