SL/R230: Flaps on Trunk Lid - Convertible Top Operation
Old 10-28-2010, 07:36 PM
robdog's Avatar
2005 SL500, 1977 450SL, 2007 Cadillac Escalade
DIY Trunk Flap Repair
Hope this link works. I replaced myself - $58 parts from dealer (incl tx) and about 20 minutes. Thanks to NikleinR6!
https://mbworld.org/forums/sl-class-...ml#post4226671
Old 10-28-2010, 08:00 PM
framici's Avatar
2003 SL 500
flap repair
Does anyone have instructions on how to fix the loose flap. The part should arrive today. thx
Old 10-28-2010, 08:09 PM
robdog's Avatar
Check the link above - post #26. The trick is getting the flap TIGHT up against the trunk lid before you attach the new bracket. Might have to fiddle a bit with the adjustment nut to make sure the teeth are aligned. Good luck!
Old 12-02-2010, 04:24 PM
mig1980's Avatar
2003 SL55, 2006 CLK500, 1998 Vette
Hi there guys. a friend is having a similar issue. He has an 04 SL500 and the two smaller flaps came off. The place where they attach on the lafter and right boot sections is broken. Will this rebuild kit replace those pieces? Any ideas would help me help him.
Old 12-02-2010, 05:09 PM
robdog's Avatar
Came off? Not sure if this will help. Did you click the link in post #26 above? It has some pretty clear pictures including one that shows the replacement parts. This fix is for flaps that won't stay tight against the trunk lid preventing operation of the vario roof. If something has broken off it may be a different issue. Good luck!
Hey framici, how did your repair go?
Old 12-02-2010, 05:41 PM
mig1980's Avatar
Yeah, I just opened the link above and those are different flaps. Guess this won't help. Thanks anyways.
Old 10-08-2012, 11:02 PM
  #32
purefct's Avatar
SL500
I found the same thread as robdog
https://mbworld.org/forums/sl-class-...l?#post5386705
It's an awesome proceedure! I ordered the part from parts.com, cost $48.99 with CA tax and shipping When you order it says Qty 1 but you are getting two brackets in the order. Took me 25 min on first side (reading, thinking, tool collection), then less than 10 for the second!
The stronger brackets P/N 2307500111 are all you need! I inspected the ones I removed and there was a slight bend in them, allowing the gears to slip!
Old 04-19-2019, 04:59 AM
  #33
Sacredspirit's Avatar
Mercedes 320 clk convertible w208
W208 convertible side flap part missing
On my Mercedes clk convertible w208 This is missing on drivers side don’t know what it’s called
This is the part I’m after any help would be great thanks
Originally Posted by Turbo35216
I have an 03 SL500 and sometimes, when closing the roof, the flaps that are folded up under the trunk lid drop a bit and stops the tops operation. They fold out when the top is down and no issues.
Seems like the only time it ever happens is when I am on a date or pulling up in the valet line at a busy restaraunt. Wonder if she is getting jealous.
Is there something I need to tighten to keep this from happening? Read through the threads and didn't see another post like this. Trust I'm not the only one.
Old 04-19-2019, 04:58 PM
  #34
alk247's Avatar
2003 SL500
This is the wrong forum.
Quick Reply: SL/R230: Flaps on Trunk Lid - Convertible Top Operation
