SL/R230: Roll bar won't go back down
Old 12-03-2008, 05:41 PM
rodin66's Avatar
SL 500
I yumped a bit on a back road last night and my roll bar got nervous and deployed -- Damn thing wont go down (and its longer than four hours )
Is there anything I can do EXCEPT take it to the dealer ?
Old 12-03-2008, 05:58 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
You might try disconnecting the battery for 5 minutes or so, and it may reset itself.
It sounds like you were having a good bit of fun. I track my SL55 and hit the rumble strips while apexing corners and generally fling it around and I have never had the roll bar deploy! Well Done!!
Old 12-03-2008, 06:05 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
If I remember correctly resetting an R230 roll bar is the same as an R129 car. You press the "raise" roll bar button for a few seconds until you hear an audible "click". This resets the roll bar mechanism which then allows you to lower it.
The following 3 users liked this post by bobterry99:
AMG_55_cruiser (06-17-2021), markmatt (02-02-2023), vmarcial27 (04-05-2020)
Old 12-03-2008, 06:59 PM
rodin66's Avatar
SL 500
Dino
It was one of those yumps where the road alters course slightly (in mid yump) 10 points
Old 12-03-2008, 07:01 PM
rodin66's Avatar
SL 500
Thanks -- I think I tried that as i was pushing up and then down like a madman
I'll try it more controlled and maybe disconnect the battery as Dino suggested as a 2nd last resort -- Last resort being the dealer visit
Old 12-03-2008, 08:44 PM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
You are correct.
Simple fix.
Old 12-04-2008, 11:04 PM
jettur's Avatar
2003 SL500R
I had the same problem last year; I held down the 'up' button for a while and then tried to lower it. After a couple times it went back down, and it's been working fine since.
Old 12-11-2008, 03:38 PM
rodin66's Avatar
SL 500
Thanks everyone -- The holding down the switch routine worked great
Old 12-12-2008, 01:07 AM
Well done!! Time to go attack that road again. Now you know how to reset it, so fling away!
Old 10-02-2009, 08:56 AM
cal1's Avatar
SL55, ML500 & Acura TL
Thank god for the search function on this forum. Not only did I learn how to reset my roll bar, I learned that I must have yumped a bit
I was at WOT in first gear when the front tires rolled over a slight hump in the road. Just at that moment, the tranny shifted to second with a kick like a bull and the rear wheels launched off the hump. Snap goes the roll bar followed by massive amounts of smoke from what used to be tire tread. A slight controllable drift through second and into third and back off the throttle and the best part of the ride was over. The rest of the ride was spent convincing my wife that I am not a complete moron and I didn't break the SL.
Old 10-02-2009, 07:19 PM
gqa
gqa's Avatar
05' sl 500
LMAO
Old 07-13-2012, 02:14 PM
goralC63's Avatar
was C63 Now SL55
Roll BAR stuck in UP position.
I have 04 SL55 and today my roll bar got stuck in UP position.
I tried all what I have read in this thread but nothing works.
Holding "up" button, Holding "down" button.
NOTHING WORKS.
Like there is no power going to the roll bar.
It did no go up because of aggressive driving.
I left the car with the roll bar UP and when i stared in the morning It WON'T go down.
What should I do?
Old 08-15-2012, 11:15 PM
NOTHING WORKS.
What should I do?
My normally bullet proof SL55 has a stuck roll bar as well.
Mine appears to be fully raised, but when I start the car the dash states "raise roll bar". However, when I try to raise or lower the bar I just hear clicking. Even when I attempt to lower the roof, nothing happens and the roof won't go down.
Any ideas?
Old 06-22-2013, 06:01 PM
markschue's Avatar
SL55
Thanks for solution
Thanks for the solution guys~!
I was going through an intersection over some railroad tracks and got all 4 wheels in the air. It was a hard landing and I was concerned about my ABS. That seems fine, but the roll bar was up. Like others I could not get it down, nor my top back up. I get the raise roll bar message on my dash.
I just followed the instructions. I pushed the raise roll bar button for a few seconds till I heard the click. Not very loud. Once I heard the click, I hit the lower button, and the bar came down and my top then was able to go back up.
Thanks again for the solution and not having to go to the dealer for such a simple fix!
Old 07-11-2014, 11:41 PM
PS94's Avatar
2004 SL55 AMG Kompressor
Digging this post up again....I may have been too spirited in my driving as well...bar was up....was getting into full panic mode...holding up worked and my bar went down!! whew!!!
Old 07-12-2014, 12:23 AM
diablo2112's Avatar
2007 SL550
I think the mechanism for the roll bar has 2 parts: a normal motor, and a much faster emergency activation mechanism, which is pneumatic? The pneumatics raise the bar much more quickly than the regular servo mechanism.
When you have the bar raised due to enthusiastic driving, it's this second pneumatic mechanism that has raised the bar. The first, motor-driven servo mechanism is still in the position with the bar closed. By holding the "up" button and waiting, you're actually moving the servo mechanism back to the raised position. Once raised, the appropriate bit of the servo mechanism re-engages with the bar, which is the audible click you hear.
Makes perfect sense.
Old 07-12-2014, 09:51 AM
cal1's Avatar
^ The bar pops very quick in an emergency. Start looking between the seats and back toward where the roll bar is at about 52 seconds in. The vid is pretty funny too if you haven't seen it.
Old 09-08-2014, 01:55 PM
leander1966's Avatar
1999 clk320
roll bars wont go down 1999 clk
I have a 1999 clk and the roll bars are stuck up. I have tried the hold the switch up for 8 secs but nothing. I show on youtube how to lower them manually, but It was on a 2002 abd my car looks different. Does any one know how to to do this ion a 1999? or have a manual? Help!!!
Old 02-09-2015, 01:52 AM
va22il's Avatar
SL 500 2007 R230
Roll Over Bar Stays Up! Please help???
Hi Guys, I am driving SL 500 R230 2007. Few days ago I accidentally jump over one island on the street which cut both of my tires on the passenger side. I then realized that the roll over bar deployed as well. I tried everything what you wrote previously and when I start the car I get the message "Raise Roll Over Bar" I push the raise button and hold it until the relay clicks and the motor stops rotating but it does not want to catch up with the roll bar and to be able lower it down. What can be the reason? Is there any manual lock which I can release? Or something is broken and I need to change it? Please let me know what do you think cause I try to find answers in internet and there is very little about the subject. Most of the mechanics does not have any idea and I don't want to fix it some how and in case of accident the bar not to open. Thanks in advance!
Old 03-14-2015, 09:26 PM
LAZARU5's Avatar
EQS 450 4Matic SUV
The roll bar in my 2008 SL550 deployed when I was fishtailing after slipping off the edge of the pavement at the Mid-Ohio track. Holding the raise bar button to re-engage the mechanism did not work. Fortunately the car was still under warranty. As I recall, a bracket got bent when the roll bar deployed and this had to be straightened out in order to lower the bar.
Fixing a roll bar that is stuck in the up position is not particularly easy because the top cannot be lowered with the bar in the up position. I believe the passenger seat and all of the trim panels in the rear of the car had to be removed to access the roll bar mechanics.
It's a good idea to raise the roll bar manually before you engage in any spirited driving or track the car.
Old 10-05-2015, 12:23 PM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
YESS , thank you, worked perfect .. if not start engine, you can hear servo motor working til it reach the top, and catch up with with roll bar. is good idea if making spinn out ,around to raise the roll over bar first ..
Old 10-02-2017, 01:27 PM
Mdgarzone's Avatar
SL55 AMG
Roll bar won't go up
i can't get my roll bar to go up on my 2006 Mercedes sl55 amg, any suggestions?
Old 10-04-2017, 05:01 PM
Vader1's Avatar
2004 SL55 AMG
This is correct. The same thing happened to me.
Old 10-04-2017, 09:29 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Yep - it's in the owner's manual:
Old 10-05-2017, 03:17 PM
Sarc1218's Avatar
SL55, SL500, SLK320, ML320, CLK 430
Roll bar
This happened to me but nothing worked. In desperation and after a ridiculous quote from dealer saying I needed to replace the pump for my top. I checked a relay that was attached to the pump in the hood, it was bad, replaced it and have been good to go since.
Quick Reply: SL/R230: Roll bar won't go back down
