SL/R230: Trunk Soft Close switch
Old 11-05-2009, 09:12 PM
bahamas's Avatar
2003 SL500 and 2005 E320
Does anyone know how to get to the trunk soft close switch on a 03 SL500..additionally where is the pump that is activated by this switch located.....
Old 11-06-2009, 02:07 AM
glennbaz's Avatar
2003 SL500
trunk not soft closing
Before you go crazy because your soft close is not working, disconnect the battery in the trunk for 20 seconds and reconnect. See if the fixes your problem.
Glenn
Old 11-06-2009, 11:06 AM
bahamas's Avatar
trunck soft close
did as you suggested.....now it works perfect...thanks for the help I appreciate it
Old 11-09-2009, 04:49 PM
bahamas's Avatar
well it seems to be happening again...it will work for a few times then goes back to its old ways....any suggestions
Old 11-09-2009, 08:20 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
take it to the dealer or MB tech with DAS/Star system for proper diagnosis.
Old 11-09-2009, 10:32 PM
glennbaz's Avatar
2003 SL500
Sorry it wasn't a long term cure. Do a search on past threads as I remember people with the same issue. One in particular had it clear then come back in a few days. I'm not sure what his final cure was. It was either on this board or the "other" one. Sorry I don't have more info.
Good luck. As far as bringing it to MB stealership, I would hesitate because I had the same problem several years ago and they "replaced" the pump. Years later I find out that the same pump controls many different functions and ALL of them worked fine. My thoughts is they just reset the unit and charged for a new pump.
Glenn
Old 11-10-2009, 07:15 PM
Rick SL55's Avatar
Glenn
same thing happen to me, but is not so frequent. I was told by service advisor they will have to reset the unit. Now that I have a Star system will try to reset the unit. will keep you posted.
Quick Reply: SL/R230: Trunk Soft Close switch
