SL/R230: Help! Trunk boot lid not closing! urgent
Old 05-11-2010, 11:05 PM
sikhkd's Avatar
AMG
Well I had my top down on the way back home, opened my trunk midway to add something, and now my trunk doesn't close completely.
I tried everything, slammed it down, and it doesn't close by itself anymore.
If I try to put the top back on, I get the warning "close boot lid"
I hope it doesn't rain soon, I have no idea what to do..
Any help please?
Old 05-11-2010, 11:23 PM
glennbaz's Avatar
2003 SL500
Do the door locks still work? If not then it's probably the vacuum pump. If they do then the trunk assist latch if probably bad. Not a major problem.
Glenn
Old 05-11-2010, 11:46 PM
sikhkd's Avatar
AMG
door locks work fine. I read somewhere to take out fuse f20/ and that seems to be fine as well.
still not working, ugh this is frustrating.
Old 05-11-2010, 11:51 PM
glennbaz's Avatar
2003 SL500
Try disconnecting the trunk battery for about 20 seconds then see if the self closer works again.
Old 05-11-2010, 11:53 PM
sikhkd's Avatar
AMG
alright I'm about to head out and try it. appreciate the help!
Old 05-12-2010, 12:21 AM
sikhkd's Avatar
AMG
I disconnected the battery for about 20 seconds and re-connected it.
it works! I was able to put up my top back on safely. hope it doesn't occur again.
Thank you!
Old 05-12-2010, 01:05 AM
VendettaMB's Avatar
His wifes head hard into the headboard nightly!!
happened to me the other day after grocery shop.......my wallet w/ keyless go was in the grocery bag in trunk and wouldnt close!
Old 05-12-2010, 04:47 AM
glennbaz's Avatar
2003 SL500
It will probably last about 2-3 days and then you might have the same problem again. If so, you might be looking at that new trunk closer latch. Been there, done that.
Glenn
Old 06-25-2010, 04:06 PM
Onash's Avatar
95 E320 Cab (new toy), 06 Range Rover (Hers), 97 Ferrari F355, 05 Ariel Atom 2 (the other toy)
I'm experiencing the same problem with the trunk assist. The dealer quoted me $1,200 (pump is $900). I told him to leave it alone.
I need to source it from an aftermarket store, anyone know where?
I'm still going to try the disconnect for 20 second method first.
Old 06-25-2010, 04:55 PM
NikleinR6's Avatar
08 ML350, 2011 E550 Cab
I just posted this up recently..
https://mbworld.org/forums/sl-class-...w-fix-diy.html
Its a very common problem our cars have....
Nick
Old 11-27-2012, 01:32 AM
sikhkd's Avatar
AMG
Nick
Thanks for the write up. I was just coming back into this thread because the trunk assist doesn't work anymore, I've learnt to slam the trunk so it closes it completely
I will try the DIY soon to see if my trunk assist still works, which I doubt... but will give it a try!
Old 06-18-2013, 04:18 PM
ldam's Avatar
2003 SL500
2003 SL500 Trunk Can't Open
My SL500 occasionally not able to close & latch the trunk properly. I recently followed suggestions from the forum and found a vacuum leak on the latch mechanism; which I used super glue to seal the leak at the big port and also the rest of the remaining small, unleaked ports as a precaution. Now putting everything back, the trunk locks & latches fine but it won't open with the remote anymore; instead, I have to use the mechanical key to open it. The remote is no longer able to open & lock the doors as well. I've disconnected the Neg side of the service battery several times to reset but still no luck. Any help/guidance would be greatly appreciated. Notice, when ever I tri to open the trunk with the smart key, I still hear the latch actuates but it won't pop open the trunk. Please help.
Old 08-01-2014, 04:33 PM
Iagoman's Avatar
E-250 CDI 2014
trunk lid opens when it closes
I have a 4 month "old" 2014 MB E-250 CDI. Great auto, but the trunk often opens after I press the "lock" or "close trunk" button.
Since I am under the new car warrantee, MB has ordered a new cable and trunk handle. Seems like a waste to have that costly repair.
You would think they could just repair something? Nicht wahr?
Old 08-02-2014, 01:02 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
Mine didn't work until I did this fix and now all is well--I think you will be impressed.
Quick Reply: SL/R230: Help! Trunk boot lid not closing! urgent
