Go Back   MBWorld.org Forums > Mercedes-Benz SLR & SL Roadsters > SL-Class (R230)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 12-03-2011, 12:22 PM   #1
I think the previous owner lowered the car too much - not sure what to do NEED HELP
My 03 that i got last week with 24k miles i knew looked different and i think i know why now. When the car is sitting at the lowest setting it is so very close to having the wheels rub the fenders, when i turn the wheels all the way it is fractions of an inch away. I also noticed that there is paint missing from the very bottom edge of the fender that definitely happened from tire wear - i am NOT happy about this as the car is mint mint mint
I think perhaps it is so close when you are turning if you hit a bump that is enough for the car to rub
If i push the raise car button to one light it looks like most other SL's and if i push it up again to two lights it looks too high.
I dont want to spend money getting everything recalibrated. Is it OK to drive around with the raise button showing one light. There is nothing wrong with ABC,etc. Clearly someone did this on purpose and perhaps was off by a touch. It has michelins with about 80-90% tread left, i wonder if when they were brand new that is when the paint scuffs happened
Please advise, i am really ticked about this.
To remove this ad, register today or login if you already are registered!
__________________
2007 S550 Black with AMG Package
2003 SL500 Obsidian Black with AMG Package FOR SALE
2003 S500 Alabaster White with AMG Package
2008 GL450 Arctic White
Robertpel9 is offline   Reply With Quote
Old 12-03-2011, 01:31 PM   #2
HemiTom's Avatar
Drives: 2004 SL600 Renntech
Tom Hunsaker
You can leave it raised up with one light on with no problems. It may have a lowering module installed or lowering links.
HemiTom is offline   Reply With Quote
Old 12-03-2011, 01:44 PM   #3
Drives: 04 CL55 (sold), 2012 CLS550
theres not a lot of ways to really lower the car, so if you can find out "HOW" they lowered it then you should have no problem reverting it back to stock
__________________
danlnyc is offline   Reply With Quote
Old 12-03-2011, 02:04 PM   #4
B R
B R's Avatar
Drives: 2010 Taco
Quote:
^ Easiest thing to do, boom you are done.
B R is offline   Reply With Quote
Old 12-03-2011, 10:50 PM   #5
Thanks for the info.
I just measured and at the lowest setting it is under 26" which is too low. At one light it is at 26 3/8" so i guess i will go for that and if i was ever at a car show or something i can drop it to the under 26" level it was about 25 3/4 to 25 7/8. It still looks good at the one light level
What is a stock setup. When mine is on two lights it almost looks close to what i am used to seeing
I wonder if i was the one that made the wheel rub and remove a little paint on the bottom of the fender lip. You can see it unless you crawl under. I am going to touch it up to prevent further issues. Maybe the last owner knew to drive it on one light
Doesn't the car lower itself when over a certain speed, i hope it is ok on one light on the highway
Thoughts?
__________________
Old 12-03-2011, 11:07 PM   #6
Thoughts?
__________________
Tags
button, car, cars, dropped, install, links, low, lowered, lowering, owner, ownership, previous, problems, sl500, undo, whats
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
