SL/R230: Trunk will not unlock with keyless, only key blade works
Old 05-26-2013, 06:57 PM
SPIKES's Avatar
2019 S63 COUPE
my trunk does not pop open when I hit the trunk button on my key remote. It does not open when I touch the lever either (I have the keyless go option). I have to use the key blade to open the trunk. However, the suction on the trunk does work and when i close the trunk it sucks close. The trunk release button on the driver door does not work either.
Old 05-27-2013, 08:32 AM
SPIKES's Avatar
2019 S63 COUPE
i can hear a motor running for about 5 seconds when i try to open it.....something mechanical on assembly?
Old 05-27-2013, 11:16 AM
SPIKES's Avatar
2019 S63 COUPE
sorted...thanks
Old 05-27-2013, 04:37 PM
1BGS's Avatar
2003 SL 500 / 2000 SL 500 / 1991 300 SL. / 1968 280 SL
fixed ???
What was the magic remedy...I have something similar ...
Thanx,
Bruce
Old 03-15-2015, 08:41 AM
guillaume's Avatar
r230
I have this problem which can help me?
" my trunk does not pop open when I hit the trunk button on my key remote. It does not open when I touch the lever either (I have the keyless go option). I have to use the key blade to open the trunk. However, the suction on the trunk does work and when i close the trunk it sucks close. The trunk release button on the driver door does not work either."
txs
Quick Reply: SL/R230: Trunk will not unlock with keyless, only key blade works
