SL/R230: 2003 SL500 Ballast or igniter
Old 06-15-2013, 05:02 PM
ilovemaui1's Avatar
1992 500E, 1994 E500, 2011 E550 and 2018 GLE350
I am having an intermittent passenger low beam failure. One day it works and the next day it doesn't. I've done some searching and found a few threads about igniters and ballasts. Is the igniter the same thing as the ballast? Is there a way to diagnose without tearing things apart. My research tells me I have to remove the front bumper to get the headlight assembly out.
Old 06-16-2013, 12:13 PM
rune solem's Avatar
SL 55 and a GT 3000 vr4 Here's my car: http://home.online.no/~ludvs/index.cfm
Changing the igniter on the sl
I had the same problem with my sl 55, I had to replace the ballast (same as igniter).
I took it to the dealer, I also thought the bumper had to be removed, but I'm not sure if they did that.
I paid for 2 hours work.
You also have to connect the star computer afterwards to get it working again.
The only big minus is the cost of the ballast.
Here in norway I paid 1167 dollars for it.
Old 06-16-2013, 01:14 PM
ilovemaui1's Avatar
The ballast can be had on ebay for about $100.
Old 06-17-2013, 06:00 AM
rune solem's Avatar
Ok, thanks for the tip!
Old 11-29-2015, 02:42 PM
tkkben's Avatar
2004 sl500
I just replace the ballast in my 2004 sl500. Just to let you all know that the ballast could be accessed from the bottom of the car after removing the plastic shied under the car. Only 3 screws holding it and could be done within half hour. You don't need to remove the whole lamp suggested by others which mean loosing the bumper to access the screw holding the lamp. However ignitor is inside the lamp which you might have to remove the lamp. Bottom line, replacing the ballast for the headlight is VERY easily done from under the car.
Old 12-26-2015, 07:45 PM
cjennjr's Avatar
2005 SL500
That is great info! After 20 minutes or so, my passenger bulb goes out. I turn the low beams off, and after a minute or so I switch them back on and they work perfectly! I know it's not the igniter because if that was the case they wouldn't come on at all. I will order a new ballast off Ebay and install. Thanks again for the info!!!
Old 01-01-2016, 07:37 AM
rune solem's Avatar
The igniter and ballast are the same!
And the light will work a while, but then it stops.
On my car it came and went, then went completely dead, so I had to replace the part.
Old 01-01-2016, 02:09 PM
BlownV8's Avatar
Received 1,003 Likes on 810 Posts
E55, GLS450, GL63, GLE350
You already posted this information a year and a half ago. See post number 2 in this thread.
Quick Reply: SL/R230: 2003 SL500 Ballast or igniter
