SL/R230: sl500 hard top adjustment
Old 08-21-2014, 05:08 PM
BarryVallance's Avatar
2006 sl500
Question sl500 hard top adjustment
My 2006 has the 'creaks' when the top's up but not when down. Makes me think the locking mechanisms for the top need 'adjusting'. Is this something others out there have experience with..?
Old 08-21-2014, 09:05 PM
pleeson's Avatar
2022 GLC 300
The front edge of the roof should be 4mm from the top of the window molding and even on both sides.
There is a 10mm bolt under the trim above the visor that allows this to be adjusted.
Takes a little fiddling...
This solved similar issue for me, and also stopped water dripping!
Old 08-21-2014, 10:01 PM
2006 sl500
...thanks, Phil. I will check this and let you know if it does the job.
Old 08-22-2014, 09:06 PM
lenzhotrod's Avatar
2003 500SL
Sometimes the creaking noise is the rubber. Clean both surfaces and put on some kind of rubber dressing and the noise will go away.
Old 08-23-2014, 06:22 AM
fxrs1955's Avatar
2014 SL550
You might check the clips that hold the headliner on, the rear ones are known to come unglued from the headliner.
Old 08-29-2014, 12:19 AM
cjennjr's Avatar
2005 SL500
Can you stop the top in the middle of its ingress/egress in order to service it? I want to apply rubber dressing to all appropriate parts because mine squeaks sometimes...
Old 08-29-2014, 01:46 PM
arnsbrae's Avatar
Weekend: 2010 SL 350 r230 Weekdays: 2018 E220d Coupe
You can stop the roof at any time in the cycle by taking your hand off the switch. That is for a 2010 SL...
Quick Reply: SL/R230: sl500 hard top adjustment
