SL/R230: 2005 SL500 ABC buttons function
Old 09-06-2014, 10:55 AM
sifis's Avatar
2014 SL550
I own a 2005 SL500 with ABC issues.
I am trying to learn/understand how the 2 ABC buttons on the center console function.
One button is an ABC on/off switch with a red light on/off.
The other button has a picture of the car with an up arrow & 2 on/off red lights.
How does it work?
Can you raise the car up/down?
Thank you.
Old 09-06-2014, 11:19 AM
fxrs1955's Avatar
2014 SL550
If you have an owners manual it explains it all.
Old 09-06-2014, 12:41 PM
seven_out's Avatar
SL500, Miata
Originally Posted by sifis
One button is an ABC on/off switch with a red light on/off...
There should be no on/off button for ABC.
With one LED lit the car is raised approximately half an inch; two LEDs approximately 1 inch.
Old 09-06-2014, 12:54 PM
sifis's Avatar
2014 SL550
ABC buttons
How do you lower the car?
Thank you
Old 09-07-2014, 06:54 AM
fxrs1955's Avatar
2014 SL550
Thank you
If you want it lower than stock you'll have to install a lowering module or lowering links. Lots of articles about both in these forums.
Old 09-07-2014, 10:41 AM
sifis's Avatar
2014 SL550
ABC buttons
I changed the ABC pump & the rear accumulator & rear block valve.
The driver side is higher than the passenger side.
The driver side rear is higher than the passenger side rear.
The driver side front is higher than the passenger side front.
How do I correct the problem?
Will Rodeo correct it?
Thank you.
Old 09-07-2014, 12:18 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
Thank you.
A rodeo will not correct that, however, the heights can be adjusted with a MB Star computer. You can also buy adjustable sensor links and fine tune it that way.
Old 09-07-2014, 12:20 PM
next2pool's Avatar
How does it work?
Thank you.
The button that has just one LED wil set the system in sport (light on) or normal (light off). The button with 2 lights controls the height in two different stages.
Quick Reply: SL/R230: 2005 SL500 ABC buttons function
