SL/R230: ABC sportmode?
Old 09-28-2014, 12:12 PM
Bigsnake's Avatar
MB SL500 R230
ABC sportmode?
Hi. I Have a SL500 2003 with ABC. In confortmode the car is very soft. To soft for my tast. In Sportmode it is okey. Can the car's ABC system be damage if I constantly drive in sport mode?
Old 09-30-2014, 07:13 PM
Vulcaneer's Avatar
C300 4MATIC And formerly 73 450SL
It should not be damaged. Unless there is a weakness somewhere in the system. My understanding is that the Sportmode applies a bit more pressure through the system, in order to firm it up. When new your system is designed to withhold that pressure with no ill effects. But after some years and mileage, some parts can begin to wear, or become a little weaker. There is no way to tell without inspecting your vehicle. Even then, you never can tell.
Just run it and be prepared to repair. Chances are if running Sportmode causes a problem, then it just found a problem that was going to occur later on anyway. It just happened a little sooner. My opinion.
Old 09-30-2014, 08:12 PM
OldKneeDragger's Avatar
SL600
You must have much better roads than I... If the roads are good, I can't imagine why it would be a problem. The public roads around here are subject to such variation that the sport mode is just too harsh.
Old 09-30-2014, 11:57 PM
Bigsnake's Avatar
MB SL500 R230
Thanks for the replies. The problem with the suspension is that there is no antirolbar in the rear. This feels clearley when to overtake another car. When accelerating sharply while swinging out to pass the car in front it feels like the rear end loses traction and body roll part. This disappears when running in sports mode.
Old 02-23-2015, 11:12 AM
AMG.SPORT's Avatar
SL 500 R230
Hi only just got my SL500 so still finding out what does what . is it in sport mode when red light is on
Old 02-23-2015, 11:42 AM
RoundTheBenz's Avatar
SL550 Designo Crystal & Red Interior - SL55 Silver & Black Interior - E550
Sports mode will appear on your dash with the "S" symbol. You can change from S, W or M (manual if you have it) by clicking the button in the upper left of the gear shift lever.
Old 02-23-2015, 12:07 PM
Bigsnake's Avatar
MB SL500 R230
If you can't feel the differens when you turn the steeringwheel from left to right there is someting wrong with the ABC
Old 02-23-2015, 12:44 PM
AMG.SPORT's Avatar
SL 500 R230
Thanks mate
Old 02-23-2015, 01:46 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
I think we are confusing two different things here. The ABC sport mode is controlled by the button marked ABC and has 1 light on it. The transmission programming is controlled by the button near the top left of the shifter. S on the cluster means summer, W means winter, and M means manual if you have steering wheel buttons.
Old 02-23-2015, 01:59 PM
AMG.SPORT's Avatar
SL 500 R230
thanks
Old 02-23-2015, 02:52 PM
Well damn! Only had a Merc for 10 years.... Thanks Next2pool for the education and sorry for confusing things AMG.SPORT.
Old 02-23-2015, 08:24 PM
next2pool's Avatar
HaHa--it takes 10 years to figure these things out!
sdieter (07-03-2016)
Quick Reply: SL/R230: ABC sportmode?
