SL/R230: SL 350 (R230) - Delay in start when Engine warm
Old 10-20-2014, 12:28 PM
poleman's Avatar
SL350 (R230)
Hello everybody
I am facing the following problem, which arleady 2 Mercedes dealer workshops have been unable to solve: In the morning when I turn the engine on to go to work, everything is normal and the engine fires-up in less than 2 seconds. However, when i drive for a while, say 10-20 miles and then stop/park , and leave the car for 5 minutes or more, when i get back to turn on the engine it needs at least 5-8 seconds of starter motor use to get fired-up again. However, if I leave the car for over 4-5 hours (or overnight), then the engine fires-up immediately . U can imagine that on busy days with the car , my battery gets exhausted by using so much of its energy for the starter motor. This has come to a point that is embarassing, as nearby people turn their heads when they listen to this prolonged starter motor use, obviously to see which is the car that rin out of petrol !!
Lastly please note that i have changed fuel filter twice and the tank is more than half full, so the reasons dont lye there..
Any help welcome. Thanks
Old 10-20-2014, 09:35 PM
Nosmo SL55's Avatar
2004 (MY05) SL55
My immediate thoughts are crank position sensor. Do a search on this topic and see if your symptoms match others who have diagnosed the CPS as the issue.
Old 10-21-2014, 07:16 AM
poleman's Avatar
SL350 (R230)
thank you Nosmo . Unfortunately i ve had this changed about 6 months ago, as the car would not start at all when warm. after the change , the car would start , perfectly normal in the mornings , but with a lot of starter motor in between drives.. i am not a mechanic, but is there any way the MB dealer to had it installed incorrectly ??
Old 01-29-2015, 12:36 PM
MarkDnr's Avatar
2000 VW Passat V6
I have been experiencing this exact same problem with a VW. Fuel pump, Fuel Injectors are fairly new, Fuel Regulators are functioning and Coolant Temperature Sensor was replaced.. twice. No VW Mechanic has been able to figure out what the problem is. They all had one thing in common, those dollar signs in their eyes.
Old 02-15-2015, 02:05 AM
cyglee's Avatar
2003 SL500
A post on a Porsche 911 forum reported replacing the fuel pressure sensor for fuel tank solved their similar problem.
Quick Reply: SL/R230: SL 350 (R230) - Delay in start when Engine warm
