SL/R230: 2007 SL550 Battery Suggestions
Had my "consumer"/trunk battery replaced. A mechanic looked at it and said it was substandard replacement. (CCA 680; CA 850; not AGM.) I am learning about this now. Is this a concern (the mechanic said it my or may not cause issues). Any suggestions about the best battery to use?
2007 SL550
Just had mine replaced front and back with MB OEM, $600, from what I was told by the service folks (which I trust) problems can occur, resulting in electrical problems. Car also needs to be re flashed.
C300 4MATIC And formerly 73 450SL
The rear battery is AGM. Commonly referred to as "Gel Cell". And it is a maintenance free deep cycle battery. These batteries can be run down to about 50%, and recharged many times without harm. In this application, the battery does not need a high rating for cold crank amps...because it does not start the engine except for emergency back up to the engine battery. And instead these batteries typically have a higher Amp Hour Rating. This is so it can hold a charge much longer in use. And have longer sustainable usage cycle.
Without a doubt, the AGM deep cycle battery is best for that application. And as far as I know, there is no after market replacement available. Only Mercedes OEM battery.
May want to check into this one.
http://shop.advanceautoparts.com/p/a...chTerm=battery
I have used a similar AGM battery from Advance Auto in my Porsche and was very impressed with it.
I just purchased Consumer Battery for my 07 SL 550. Advance Auto Parts has
the H6 AGM for 171. There is a 20 percent online discount and a 25 dollar rebate going on now. Great deal. Dealer said just take the old one out and replace. No reset req'd.
