SL/R230: 2002 (r230)ABC leak from HYDRAULIC STRUT SHOCK PRESSURE VALVE
Old 01-15-2015, 11:48 AM
rover75golf's Avatar
Mercedes SL500 (R230), Honda CBR 1100 Super Blackbird, Honda CBX 1000 Pro Link
Question 2002 (r230)ABC leak from HYDRAULIC STRUT SHOCK PRESSURE VALVE
Drove into the garage and noticed oil leaking from just behind front left hand side wheel. Checked out posts and its an ABC leak. Removed the wheel and the inner arch covers and found oil which appeared to be coming from the valve. ON closer inspection it appears that the seal between the body of the valve and the electric switch has broken / frayed !! see pictures. Question I have is can I remove the switch and replace the seal or is it an integral part of the valve ?any ideas suggestions welcome ? Thanks 2002 (r230)ABC leak from HYDRAULIC STRUT SHOCK PRESSURE VALVE-merc-valve-3.jpg
2002 (r230)ABC leak from HYDRAULIC STRUT SHOCK PRESSURE VALVE-merc-valve-4.jpg
Old 01-16-2015, 10:53 AM
kbob999's Avatar
'08 S550 P3; Golf Carts; MT Bike; Scooters
Seals...
Search posts for valve block seals DIY.
You should be able to find seals for the electronic valves that others have used successfully.
If the leak is from a hose seal, you will need to do more searching...not sure of the size, or if it can be repaired.
If the leak is the accumulator, then replace it.
New these blocks are over $1000, so it's a great savings to repair rather than replace.
Old 01-16-2015, 01:41 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
Originally Posted by rover75golf
Drove into the garage and noticed oil leaking from just behind front left hand side wheel. Checked out posts and its an ABC leak. Removed the wheel and the inner arch covers and found oil which appeared to be coming from the valve. ON closer inspection it appears that the seal between the body of the valve and the electric switch has broken / frayed !! see pictures. Question I have is can I remove the switch and replace the seal or is it an integral part of the valve ?any ideas suggestions welcome ? Thanks Attachment 302144
Attachment 302145
Attachment 302146
Attachment 302147
Attachment 302148
It looks like that switch will just unscrew. Since we use mineral oil, I would take the switch and go to your local hardware store and find an O ring that fits the threaded portion. Hopefully there is a relief in the surface between the switch and the housing for the seal to sit into. If not, it may require a square seal.
Old 01-17-2015, 01:17 AM
Thanks for the help and will try to sort over the weekend
Old 01-24-2015, 02:51 AM
Ok thanks for the help. Took of left hand inner skirt under wing. Found that the seal on the sensor had degraded and oil leaking from the joint. Removed the valve from its mounting and removed sensor. Fairly easy job. Had some problems iin finding the right seal but sorted and reinstalled. Topped up system with oil. Started engine but abc did not work and red warning lights came on !! After much checking and searching I removed the electrical connection from the sensor and cleaned it. Cleaned both the mIl and female connectors and sprayed with some we 40. Plugged it in and the system came to life. So a relatively easy and simple fix at a cost of about 50$ for the oil and the seal. Only tough part was reinstalling the inner wing guard. Mainly because I was working in the floor as I'd don't have a lift there is one little bolt at the back that is a pig to get in when your lying on the floor, thanks for the help and responses.
Old 01-24-2015, 08:41 AM
next2pool's Avatar
Fantastic !
Old 05-25-2015, 03:45 AM
mkirincic's Avatar
2003 SL500, 1998 E320 Wagon
So Where did you get the seal? Was it just an O ring type seal or did you have to go to the dealer to buy it?
Old 05-25-2015, 03:56 AM
I bought the seal from a local factor who specialised in repairing hydraulics on earthmoving equipment. Its a Viton seal and a its a standard o ring size so should not be a problem to buy one anywhere.
Old 06-05-2015, 03:59 PM
hlmpk's Avatar
2003 SL55 AMG
If your car is a 2002 model (or has mileage more than 50 or 60K), you might change the pressure accumulator (~$150) as well, while you had the block out (that's fine, if later on, you experience vibrations in your ABC system, you can change it.)
Old 02-18-2021, 02:35 PM
FaithMartin's Avatar
LX570
Guys, I understand that my question is a little bit off-topic, but maybe you know... How do I know if my hydraulic valve is bad? How can I test a hydraulic system? I was advised to switch to an electro-hydraulic actuator control valve and I'm still confused about what to do. This has many advantages such as very low power consumption, simple Installation, 100% duty cycle, and so on. I've really been thinking about this idea for a few months now. How do you think it is worth doing this? Thank you for your advice in advance!
Quick Reply: SL/R230: 2002 (r230)ABC leak from HYDRAULIC STRUT SHOCK PRESSURE VALVE
