SL/R230: ABC error code help
Old 02-26-2015, 07:18 PM
crazyinventor's Avatar
R230
ABC error code help
can anyone tell me what part the following code refers to; C26DC hydraulic fault: malfunction in pressure supply. Vehicle info, 2005 sl500, 69,000 miles no external leaks, ABC fluid levels correct, New ABC pump installed two years ago at 52,000 miles
Old 03-03-2015, 08:06 PM
cadbob's Avatar
2003 SL500, 2016 F250, 2017 Jeep Renegade
Its one of your accumulators, and I'm betting the Front, cheap easy fix, did mine, and while I was at it did both front and rear.
Old 03-04-2015, 09:37 AM
R230
Thanks cadbob, I was thinking the same.When you replaced the air cell on the front valve block was there any fluid loss when you unscrewed it, and how long did it take.
Old 03-04-2015, 12:02 PM
cadbob's Avatar
The Diaphragm was shot, the Nitrogen ball was filled with Black Fluid, the rest of the system was Green thank god.
Even the Mechanic who did job for me thought it was ABC Pump i said noway its pump and told him to think of his house plumbing, the house pumps from well (ABC Pump) but the Pressure Comes from the Bladder Tank (Accumulators)
It started get worse on the dips and bumps, after the replacement, I took back road home that was full of dips and bumps!
Quick Reply: SL/R230: ABC error code help
