SL/R230: Hi new here just bought my car and have ABC ISSUE ;(
320cd sport & SL55
First of all, Hi everyone, after a very long time i managed to buy myself an sl mercedes. Its a black low mile car thats been sitting for a while.
I have experienced the worst problem already and joined to hopefully make some new friends and help possibly to fix my car.
The situation is nothing happens when abc is hit. There is fluid all over the floor but the rear end is sitting high and the floor slammed to the ground. The resovoir is empty and there doesn't seem to be an obvious leak near the block valve.
However under the front middle of the engine i can just about see fluid sitting there but can see from exactly where its coming.
I am very good with cars and stripping them etc so any ideas what and where the leak could be from. Also what should i do to temporarily raise the car.
Please help. I know this is a first post.
Do not start the engine...
If your reservoir is dry, you will seize the ABC pump. Read everything you can on the forums on ABC to learn about the pump, fluid, filter, front and rear valves, four accumulators, struts, split hoses, etc. There is a wealth of information. Hopefully some experienced experts will chime in.
Probably need SDS to resolve.
If the reservoir and pump runs dry, it senses no pressure and sends a message to lock down the system. No amount of button pushing or battery disconnects will fix it. This happened to me during an ABC fluid flush.
When this occurs it flashes a red ABC warning that can only be reset with the Star Diagnostics System (SDS). You need to take it to an independent or dealer to pressurize the system and reset the warning.
Then you can tackle the leak, which is likely to be a hose. Common for this car unfortunately.
320cd sport & SL55
Thanks everyone for enlightening me and thanks kbob. Yes i have the red abc saying car too low stop vehicle. So i need to have it reset and re pressurised? Only then can i find the leak. Cheers i will try that and get back to you guys.
320cd sport & SL55
As you sound mechanically inclined start here and read up on the ABC system:
http://mercedes-abc-drive-carefully....y-part-of.html
Good link nice one Vtvette thanks
