SL/R230: SL55 Fuel Pump Relay Location
Old 05-16-2015, 10:01 PM
sl55_maniac's Avatar
SL55 AMG
Cool SL55 Fuel Pump Relay Location
Does anyone know the exact location of the fuel pump relay? I know it is in the fuse box behind the passenger seat, however, do not know which number it is.
Old 05-17-2015, 07:40 AM
TTtodd's Avatar
2005 SL65
Position T on this fuse chart.
Old 05-17-2015, 11:14 AM
SL55 AMG
Which fuse chart?
Old 05-17-2015, 11:26 AM
TTtodd's Avatar
2005 SL65
Sorry, I did try to attach it but keeps telling me I have already attached it.
I even re named it and get the same result.
go here http://www.benzworld.org/forums/r230...ory-r230s.html
Old 05-17-2015, 11:36 AM
SL55 AMG
Thanks for the help TTtodd!
I am experiencing some major lag after a very hard drive last night. It ran perfectly with my newly installed BWK. Probably the best it has ever ran. The very next morning I've noticed major lag and hesitant to reach the RPM's it would reach very easily the night before. I have a 1 year old CM30 pump so I know that is not the issue. What may this be? I am thinking coil packs or fuel pump itself. Any insight?
Old 05-17-2015, 11:41 AM
SL55 AMG
Forgot to mention, I just replaced my CPS due to starting issues. This fixed the problem (never cranked over before). However, I am still experiencing starting issues on a first cold start at times.
Old 05-17-2015, 05:11 PM
TTtodd's Avatar
2005 SL65
please take this FWIW. I am in no way shape or form a professional tech.
Just a dude on the internet.
Read the codes. Without reading codes its just a shot in the dark.
Just because your pump is under a year old doesn't mean it is not faulty.
There is a code for too high of intake temp. P20E1 I think it is.
If you think its fuel, measure the fuel pump pressure to verify.
Read codes, test and verify suspicions. Thats what I would do.
Quick Reply: SL/R230: SL55 Fuel Pump Relay Location
