SL/R230: ABC light on intermitttently
Old 06-29-2015, 11:31 AM
rogerschnabel's Avatar
sl500
2003 SL 500 ABC system repaired but ABC light comes on intermittently going over bumps in the road sometimes a very small bump sets off the light sometimes a big bump does not set off the light James Motors in Lexington can't find the cause does anyone have any ideas as to what is causing the problem and what can be done to correct the situation
Old 06-29-2015, 08:22 PM
Nosmo SL55's Avatar
2004 (MY05) SL55
My suggestion is to investigate the accumulators.
Check out this document.
http://mercedes-abc-drive-carefully....y-part-of.html
Old 06-29-2015, 08:40 PM
cadbob's Avatar
2003 SL500, 2016 F250, 2017 Jeep Renegade
accumulators I had same problem Replaced all 4 and found rear one was blown. All good now here.
Make sure you flush system after you have them replaced and if one or more are blown. The Blown ones once off you will be able to place pencil down into. Diaphragm is shot so now back pressure for fluid.
Old 06-30-2015, 11:24 AM
sl500
ABC Light on intermittently
thanks for the post great info
Old 06-30-2015, 11:26 AM
sl500
Im sure the tech didn't know this info passed it on to the service writer who will get back to me after it is discussed with the tech
Quick Reply: SL/R230: ABC light on intermitttently
