SL/R230: Replacing Fog Light Bulbs
2009 SL 550 Silver Arrow Launch Edition
If your bulb fails, there are four Torx screws in the outer housing of the assembly. After you remove them, there are three more screws holding the fog light assembly in place. Remove them and you can remove and replace the bulb.
Be careful not to touch the new bulb (wear gloves or use a soft cloth) as the oils from your skin will cause it to shatter.
