SL/R230: 2006 SL65: Boost Pressure Question...
2006 SL65AMG
2006 SL65: Is there a way to measure boost pressure (i.e. air flow) from each turbo individually, preferably with a mechanical gauge that us not permanent?
Otherwise, where is the best place to tap a line for a mechanical boost gauge?
2006 SL65AMG
MAP (kPa) @ idle = 20, @ WOT = 140 (seems low)
Calculated boost (psi) @ idle = -12, @ WOT = 5.6 (again, seems low)
IAT (deg F) @ idle = 180, @ WOT = 135.
Last 1/4 mile passes were 12.1 - 12.4 range (actual passes at the strip, not by OBD2) with rxn times around 0.2-0.4.
I'm in Florida, and it's hot as ***** right now. Just trying to determine if there is something wrong. Turbos don't seem to be whistling like they used to.
