SL/R230: ABC Pump Removal
2004 SL500
ABC Pump Removal
I am trying to remove pump and can not get the hydraulic line with the 17mm nut loose. I used a 17mm flare wrench and it started to round off the edges. Any suggestions other than cutting the line and replacing the power steering hose?
MBworld Guru
Torque spec is 40Nm which is not much. In WIS, this is the last one removed. I suspect that is to get better leverage on it?
http://benzbits.com/R230/PowerSteeringPump.pdf
stykshooter (11-10-2016)
