SL/R230: How do you remove black plastic trim around the fog lamp?
Old 07-25-2016, 07:46 PM
secondchance550's Avatar
SL550
As part of trying to make AC run the way it should I replaced evaporator temp sensor under the dash (no effect) and now ambient temp sensor (conical looking piece) which is inboard of driver side fog lamp. Normally (like my BMW) this trim would pull right out. Evidently not so easy with Mercedes SL... Anyone had success removing this plastic surround?
Old 07-25-2016, 10:53 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
There are three (or four?) Torx head screws holding each trim panel to the bumper.
Old 07-26-2016, 05:27 AM
SL550
Accessible only from the back?
Old 07-26-2016, 10:44 AM
mercy-me's Avatar
2012 E350 4Matic P2
Remove lower panels for access, unplug from the back and pull out the front.
Good luck,
Bob
Old 07-26-2016, 01:36 PM
SL550
Good luck,
Bob
Thanks!
Glad I didn't keep yanking on fog light trim piece resulting in damage...
Old 07-26-2016, 09:58 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
The fog light trim bolts are removed from the front. They are well "camouflaged" in the honeycomb pattern of the plastic.
Old 07-27-2016, 08:05 AM
SL550
Perhaps for 2003-2006. I looked it over carefully and no camouflaged bolt hole on the front. Factory service direction is to access from behind also.
Either way, I expect iCarsoft MBII this evening. I am hoping the scanner will be able to tell me which sensor and/or module is malfunctioning.
Old 07-27-2016, 09:28 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Mine is a MY2007 SL550 and I removed the fog light trim to make it easier to put clear bra on the lenses (see photo below for the bolts). But I suspect what you are trying to remove is the lower grille, not the fog light bezel. You may be able to reach the temperature probe through the fog light. If not, then remove the lower engine cover to access the lower grille from behind.
Old 07-28-2016, 12:11 PM
SL550
This is interesting. I am trying to remove the same trim except mine looks a bit different and has hexagonal pattern. I will post up a pic later. Mine definitely doesn't have bolts accessible from the front.
Old 07-28-2016, 10:20 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
What model year is your car? II know they did a slight facelift for MY2009, so if yours is earlier, it could be different. If it's an open mesh style, then it connects from behind.
Old 07-29-2016, 08:24 AM
SL550
Mine is a 2007. I don't know enough of these cars. This may be replacement bumper from different year...
Old 07-29-2016, 10:15 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
OK, I think this is how to remove it:
http://benzbits.com/R230/FogLight.pdf
Ignore the notation about it being for MY2009 and later - that is incorrect. I can tell you that MY2009 and later uses the Torx bolts (as in my photo above)
Quick Reply: SL/R230: How do you remove black plastic trim around the fog lamp?
