SL/R230: Aircon / climate control problem, help anyone?
Hi
I have a strange problem. The aircon compresser has been changed, all faults in the system/computer was reset, the aircon workd. After 20 minutes max, the aircon button went red. And when pressed it blinked 3 times and stays red.
I've just installed a new battery in the trunk as the old one did not have enough voltage. Thought that might have some influence too on the aircon.
Errors was once again cleared, and the aircon worked again....for about 10 minutes, and then went red again.
Can anyone help me?
Can anyone help me?
Your compressor was just replaced, yet your system may be low on refrigerant.
If refrigerant pressure is too low, then the climate controller will disable the compressor and continuously illuminate the AC OFF button's LED. This sets a diagnostic code in the climate controller, and erasing that code is a prerequisite to restoring operation of the compressor.
secondchance550 (08-11-2016)
Henrik Konnerup (08-11-2016)
