SL/R230: 2005 SL500 interior part question
Old 08-24-2016, 05:19 PM
trimix's Avatar
sl600/Kleemann-ecu:tcu- 2015 E250CDI -Navion MB Sprinter
I just purchased a second r230 and i am having trouble with identifying an interior part number. The car is missing one of the small flaps that covers the back when the hardtop is in the truck on the drivers side. Its square in shape and has hinges to the one side seems the hinges broke and part is gone. I tried to find it in the parts book but i did not have luck. It looks like it part of the back seat interior trim.
Any help would be appreciated.
Trimix
Old 08-24-2016, 06:38 PM
funymuny's Avatar
SL550
Common issue. That small piece alone cannot be purchased (new) separately. It is part of the larger interior cover and pricey for what you get. A fellow sells a repair kit on ebay. Also talks about it on the other forum. I'll see if I can find the link.
Old 08-24-2016, 06:40 PM
funymuny's Avatar
SL550
NOW SELLING ON EBAY:
SPANGLER REPAIR KIT is for all 2003 - 2011
Mercedes-Benz SL R230 REAR LEFT AND RIGHT EDGE COVER TRIM PANEL to fix Boot Flap broken spring hinge.
Old 08-24-2016, 06:41 PM
funymuny's Avatar
SL550
Another thread on the issue:
http://www.benzworld.org/forums/r230...nged-trim.html
trimix (08-25-2016)
Old 08-24-2016, 06:56 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
I have the assembly available to sell for the left side in color "Stone". This is the entire part -- not just the flap. If someone is interested, message me with a reasonable offer.
Old 08-25-2016, 09:31 AM
trimix's Avatar
First i like thank you for the responses. Sometimes the parts books are hard to read.
I am looking for the drivers side in light gray 201A.
Bobterry99 send me a pm with a picture and a price i see if i can use your.
The problem is the my flap is missing it on the side of a road some where.
Old 08-25-2016, 11:56 AM
trimix's Avatar
Hi all,
I looking for a black flap for a drivers side. if anyone want to sell me just the flap or the whole trim piece in black let me know.
Trimix
Old 08-25-2016, 07:46 PM
trimix's Avatar
FYI
New news spangler on ebay says next week he will be offering doors flaps with his repair kits. Problem solved with help for this excellent forum!
Old 08-25-2016, 10:56 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
FYI, that eBay kit is basically just tape cut to fit. I'm not saying that's a bad thing - I repaired my flap with Gorilla tape. In fact, I recommend everyone use some Gorilla tape on their flaps, even if they seem secure. At least that way "when" the hinges break, they won't go flying off. Now, if he has a source for replacement flaps, that's great because the only way to get one now is to buy a new $200 side panel.
Old 08-26-2016, 08:10 AM
funymuny's Avatar
SL550
With the increasing popularity of 3-D printers I suspect it will not be too long before someone is selling 'knock-off' flaps. There are a lot of parts where I would want the real thing/OEM, but the plastic flap, as long as it fit and looked right I wouldn't care. I'd buy a few if inexpensive just to have spares. That said mine are still originals. I need to investigate using tape to secure them...not sure I understand that. Thanks, Mark
Old 08-26-2016, 02:20 PM
crazyinventor's Avatar
R230
Hi Everyone, Last week I noticed my right side flap missing after a trip to the supermarket, I drove back to the store searching for the flap on the side of the road, no luck so I put the top half way up and found the flap inside the well. I repaired the flap by drilling a 1/8" hole in each of the hinges and use
d two small zip tie to secure the flap in place. I first looped the zip tie around the metal shaft that runs thru the flap. When drilling the two holes remember to support the plastic from below with a flat screwdriver to avoid breaking the cheap plastic. After you have the flap slowly tighten the zip tie with a needle nose pliers until you have the flap loose enough to flop closed. It took 15 minutes to repair, I also put a dab of glue to hold the zip tie just as a precaution.
Old 08-30-2016, 08:34 PM
hydrogen's Avatar
2005 SL500
Mate, I had the same problem. Can't buy the little flap have to buy the whole quarter panel from OE Discounts (USA) it cost about $307.00. Email a tracy there she is very helpful.
The part numbers are
The left side is P/N 23069009419C83 - $307.50
The right side is P/N 23069010419C83 - $307.50
Qty of 2 clips per side P/N 0119887678 - $1.65 each
Old 08-30-2016, 09:57 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
mboemparts has it for $303.40. I;ve had very good luck dealing with them (online store for MB of Napierville, IL).
Old 09-05-2016, 04:12 PM
webuycarnotes's Avatar
2005 SL500
C Pillar Removal/Re-Install to repair small flap with Spangler Repair Kit
Hello Community,
Here are some notes on removing the C pillar flap cover to properly align the Spangler Flap Repair Kit found on ebay by searching "Spangler Mercedes".
As you know, when the small flaps break at the plastic hinges, etc., one cannot replace just the small flap. You have to buy the WHOLE assembly, which is really pricey. Even used ones on ebay are expensive.
The Spangler Repair Kit seems like a reasonable fix!
Attached Thumbnails 2005 SL500 interior part question-broken-missing-flap-flap-cover.jpg   2005 SL500 interior part question-flap-cover-inside-showing-clips.jpg   2005 SL500 interior part question-door-end-flap-cover.jpg   2005 SL500 interior part question-metal-cover-door-end-flap-cover.jpg
File Type: pdf
Quick Reply: SL/R230: 2005 SL500 interior part question
