SL/R230: Steering wheel memory
Occasionally my steering wheel does not return to its memory position when I start the car. I have to press the memory button and it will go to its position. It always retracts up but one in 3-4 times does not return. This is a minor complaint but if there is a simple solution I would like to hear.
You might try the convenience features settings on the dash and turn it on/off and see if it helps.
Also try manually running it to the limits in/out - up/ down. This may help it to learn to range, or free up the sensors.
If you have an SDS...check for codes on a quick search.
Last resort...disconnect the rear battery for 10 minutes, and then reboot the car.
Had a similar issue with my seat retracting. With the SDS, I was able to set the retraction value to a higher number, which fixed the issue. SDS has warnings that "this may squeeze a long legged person", but I don't worry about that.
Ptrigg17 (09-09-2016)
MBworld Guru
Mine does has done this on occasion. I thought it might be because I was starting the engine before closing the door, but I can't duplicate it consistently. Oh, and no stored DTCs.
Ptrigg17 (09-10-2016)
If you manually raise the steering wheel while parked with the engine running and do not return it to it's set position, it will not re-set when starting up the car the next time. For example, I stop at my mailbox, leave the engine running, put the car in park, raise the steering wheel before I exit the car and then drive to my garage without returning the steering wheel to it's original position, it will not return to the set position the next time I crank it up. One of the car's many peculiarities.
MBworld Guru
That makes sense. But in may case, I don't think that's the cause. I never adjust the steering wheel position. I have my seat and wheel set perfectly and memorized and I never change it, with the exception of lowering the headrest if I wear a hat.
