SL/R230: 05 SL 600
Old 10-04-2016, 11:41 PM
horrible's Avatar
2005 SL 600,2002 M3,1993 Vette!
05 SL 600
Which battery should be trickle charged?
Or should it be both?
It would be nice if there was a way to start the car with the rear battery when the start battery wont.
Old 10-05-2016, 01:44 AM
JohanSL's Avatar
2006 ML320Cdi Off Road Package; 2010 E500 Cab
From what I've read here, the one in the boot.
Old 10-05-2016, 06:14 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
It should be the rear that gets the trickle charger. My understanding is that the rear will assist starting if the front battery is low or dead.
Old 10-07-2016, 07:09 AM
horrible's Avatar
When my start battery would not crank the car enough to start the car that lazy ******* in the back never helped out!
Of course, it's possible a relay might not be doing its job.
It's hard to get good work now a days!
Old 10-07-2016, 09:40 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Here's the WIS doc explaining the 2-batteyr system:
http://benzbits.com/R230/BatterySystem.pdf
An undervoltage condition on the starter battery will cause the power supply control module to connect the two batteries in parallel. Now, it remains to be seen how well this works in practice. Two old, poorly charged batteries are really no better than one. Also, a starter battery with a dead cell can act like a giant resistor and limit the output of the consumer battery.
Old 10-07-2016, 10:01 PM
next2pool's Avatar
Well it helps to know the design intent before tearing stuff apart or replacing expensive components.
Quick Reply: SL/R230: 05 SL 600
