SL/R230: Trunk lid liner plastic rivet part numbers
2007 SL550: I need help identifying the MB parts numbers for body panel plastic rivets that attach the upholstered liner to the inside of the trunk lid. I have a copy of the page from the MB parts book that shows the "exploded" view of the trunk and the rivets I need; unfortunately, the page does not provide the specific MB parts numbers for these rinky-dink but necessary items.
The page I have identifies itself as:
Picture Number B75015000039.120821
Group 75--Rear Lid
Subgroup 015--Rear Lid
The rivets I need to obtain are identified as items 30, 160, and 170.
If you can provide MB part numbers for items 30, 160, and 170, I would be most beholden to you.
Group 75--Rear Lid
Many many thanks, Rodney. The parts list is exactly what I needed. I can take it from here. And ... if I may ask ... how/where did you get the parts list?
Heatwave (10-07-2016)
Group 75--Rear Lid
Group 75--Rear Lid
Rudeney: Do you have a printer physically connected to the laptop that interfaces with SDS, or do you have an internet connection between the laptop and the printer? I ask because I may "inherit" an SDS unit from an aged friend who is selling his CLK and has no more use for his bootleg SDS. I have read posts warning against connecting to the internet laptops that have SDS software ... that MB has search tools that allow it to find bootleg SDS software and to disable it. I'm puzzled as to the best way to attach the laptop to the printer without hardwiring it, which would be a real pain.
I have a couple star das (clone) set-ups that I have been using for years but I do not have a printer attached (nor miss it).
Instead, I have a pdf writer as one of my printer choices on both of my star das testers. Which works very well for me as I save ALL of my quick test results, etc in folders that are easy to review. I use this format for labeling the PDFs .... year-month-day-vehicle-special notes (eg 2016-10-04 SL55 clear codes after top-pump failure) that way they sort by date and vehicle. When/if i need to print something (or move it to another computer to email it, etc) I just copy it to a flash drive.
hope that helps,
Chris
Heatwave (10-09-2016)
Pdf writer and flash drives... great idea. I'm not much more than a neophyte on computers. I appreciate your passing on your good ideas. Thank you, Sir.
MBworld Guru
My copy of SDS runs under VMware on a virtual drive. I have it using a NAT share on the hos PC's network, so it has Internet access. i sue Cute PDF to "print" documents.
Heatwave (10-10-2016)
R230 Body Parts list PDF
I know that you are looking for parts for your R230 and I have found this PDF with most of the parts and numbers listed including images. I am goinng to try to attach it. Hope it works
Rafdaddy: Thank you for posting the pdf containing the R230 parts. I really appreciate your doing that.
Rafdaddy: I hope I'm not bugging you, but can you post a link to a parts pdf for R230 model year 2007 and up?
