SL/R230: PSE right conections of air pipes to Pump manifold
SL500 2003 (R230)
PSE, correct conection of yellow air pipes to Pump manifold
Hi, i will appreciate any help regards to my SL500 R230 (2003) PSE pump, the problem is that i order a new PSE PUMP because the old one failed, but my mechanic forgot to label the yellow air lines before to remove them from the manifold
, and now i have no idea which yellow air line goes with which conector, my PSE PUMP has the follow capital letters marked: one side five connectors SK, HECK, ----- ,VL, ------, other side five connectors IZV, -------- VR ,TD ,MKL, (sorry my writing, english not my mothern language) maybe some one has a similar car an may send a picture in which i may appreciate the proper order of conection, i will appreciate any help, thank a lot for any help and again sorry my english, i hope i made myself understood.
Erick H.
Erick H.
SL500 2003 (R230)
Thanks for answer the VIN : WDBSK75F93F013211
SL500 2003 (R230)
hello Plutoe, my SL is a convertible 2 Doors, only has MKL TD, SK, HECK, VL, IZV AND VR,
i follow the yellow air lines and believe , TD, SK, HECK, are propperly conected, Im not sure if MKL its a gray air line, and if IZV its a yellow with a blue line on it, Thanks again por the answer
EH.
EH.
EH.
EH.
An alternative to the do nothing approach would be to get off the couch and look under\around the seats to locate the appropriate colored pipe!!
