SL/R230: Multicontour seats and soft close trunk fixed
Soft close trunk not working. Glued the bb ports of the actuator as many have done before me, also had to glue the broken hockey puck together. Still not working. R/R the fuse behind the passenger seat, now soft close works but PSE pump still running and timing out. Broke out my STAR computer and it says driver seat demanding too much air. Removed the driver seat (what a pita) and found the white air hose going to the seat had popped out of someone's previous repair. The previous repair used a slightly larger diameter black rubber hose to connect the two white hose ends that had been cut. I used a longer piece of rubber hose to hopefully prevent the white hose from popping out again. Everything works fine now.
This would have taken me much longer to find had it not been for Thorgod in post #15 of this thread.
http://www.benzworld.org/forums/r230...ontrols-2.html
Under the drivers seat
Inside the hockey puck if anyone is curious.
kbob999 (11-22-2016)
