SL/R231: cooling
Old 09-21-2014, 01:18 PM
dkeuper's Avatar
SL 550 R231
cooling
I'm thinking about getting the Renntech tune in a couple of month, with it I'd also like to upgrade the cooling system.
Does anyone know where all the coolers/radiators/heat exchangers are installed?
The engine radiator is obvious, it front I guess is the engine oil cooler, is the heat exchanger located inside the right fender?
I see nothing inside the left fender, so I think it would be possible to get a SL63 heat exchanger, put it in there and daisy chain it to keep the intake Air temperature down.
Either that or just getting an Eurocharged Performance heat exchanger should work.
What do you think?
Quick Reply: SL/R231: cooling
